Third Gen Association of Ontario Regional message board for everyone in Southern Ontario and nearby regions.
SBC block and head casting codes
Old Jun 5, 2002 | 02:46 PM
palric's Avatar
Car: 90 IROC 5.7 hardtop
Transmission: T5 swap
Axle/Gears: Yup -- they still work
If any of you are interested I have attached a list of all GM block codes, ci, the year, bolt config and source sorted by casting number.
Included is the a list of all GM head casting codes, the year they were used, block sized used on and valve configuration all sorted by casting number.
RP.
File Type: txt
Old Jun 5, 2002 | 04:17 PM
johnyIROC's Avatar
is that from mortec?
Old Jun 5, 2002 | 05:04 PM
trigger GTA's Avatar
Car: 92 TA vert
thay Palric do you have one for Chevy Aluminum Cylinder Heads. i am looking for a set from a vett to install but i dont know what the part# is
Old Jun 6, 2002 | 04:17 AM
Eric2ndGen's Avatar
I have a problem with the statement that the casting numbers will also give you valve sizes.
GM/Chevy were infamous for using the same casting on cylinder heads and using 2-3 different sized valves depending on the application.
I.e. a very common mid '70s to early '80s head, # 333882 was used in everything from soup to nuts practically- full-size passenger cars, mid-size cars, trucks, F-Bodies and on both 350 and 400 inch blocks. Known valve sizes included 2.02/1.60, 1.94/1.54 and some people have sworn they've seen them at 1.84/1.50 on some trucks. All the same casting number...
So how does this listing differentiate the heads beyond the basic casting number?
Old Jun 6, 2002 | 08:59 AM
palric's Avatar
there are some aluminum heads
I think there were some aluminum heads in the list ???
palric's Avatar
don't know ?
Don't remember where I got it -- some web based source.
Old Jun 6, 2002 | 09:02 AM
palric's Avatar
sorry
Sorry.
RP.
Old Jun 6, 2002 | 01:02 PM
92zeddar's Avatar
HEy Triggar! the heads you are looking for are..
10088113...88-up...350..........Aluminum, 58cc, angle plug, raised
"D" port exhaust, 1.94"/1.5" valves
How I know this is that i am looking for a set aswell...hahahaha
they are great heads..but expensive as hell
CRFred
Feb 7, 2016 11:39 PM
Mickeyruder
Sep 2, 2015 02:45 PM
camaro71633
Sep 1, 2015 10:24 AM
theurge
Aug 21, 2015 12:46 PM
BBSDesigns
Aug 11, 2015 07:39 PM
