engine problem
engine problem
I got a small problem, i wonder if any of you guys would have an idea. Car runs fine when driving normal. When i punch it at high speed it seems to stutter. I have a feeling that it might be an electrical problem. A buddy was looking at it for me and he burnt his finger when he touched one the spark plug wires. It was resting on a header. Is it possible that the heat could of damaged the wire or maybe it just needs an injector cleaning....
Car: 85 iroc z
Engine: LG4 :(
Transmission: 5 speed
Yes it sounds like you have burnt the wire on the header, its probably arcing on the header now. So change the wire and that should solve your problem. Also make sure the other wires are away from the headers, or you will lose spark to others too.
Car: 83WS6TA
Engine: ZZ4
Transmission: TH350C
Axle/Gears: 3:23
If a wire was cooking on the header then it's gonna be shot notwithstanding any other problems you may have with the fuel pump or whatever so you should probably change out that wire and go from there.
