Third Gen Association of Ontario Regional message board for everyone in Southern Ontario and nearby regions.
continueing engine problems
Old Oct 6, 2002 | 10:34 PM
Slashmeiser's Avatar
Well still having problems with the engine. Changed the fuel filter. Put on some new wires. I bought a set of Taylors. Also ivested in a fuel pressure guage.
I was talking to the guy at Performance improvements he thought that the fuel system should be running at somewhere around 45 psi for a 305 T.P.I. Mine is running at aboput 35. Now i'm not sure maybe he's got his numbers mixed up. Does anyone have any idea what the stock pressure should be. The car runs alittle rough now but when i push it, it still stutters like it is struggleing. Could it be the fuel pump is ready to go?
Old Oct 6, 2002 | 11:06 PM
Azure's Avatar
From: "No one cares if you're in before the lock!" - Best quote ever.
43-45 is the pressure you should be sitting at, correct me if I'm wrong, anyone...? BTW< Performance Improvements is a good place to go if you enjoy getting raped for your $$$.
Old Oct 6, 2002 | 11:12 PM
ninety1TAgta's Avatar
I believe 40 is the average stock. Not positive on that though. I would say 35 would definately run it lean at high rpms but not as bad of a problem as your describing...
greg
Old Oct 7, 2002 | 08:21 AM
palric's Avatar
Car: 90 IROC 5.7 hardtop
Transmission: T5 swap
Axle/Gears: Yup -- they still work
yet another opinion
I thought my 305 TPi ran at 38psi ?
Better make a post on the TPI board.
RP.
Old Oct 7, 2002 | 06:41 PM
nblanchard's Avatar
Was the pressure reading taken when the engine was hot, or warm? I know my 350 needs to be at around 40psi stock, I have it around 50psi (accel gauge is fubar)
Old Oct 9, 2002 | 02:26 AM
Acceld Z's Avatar
Car: 1992 Z28
Engine: 355
GM "spec" is 39-43psi at idle with the hose connected.
Old Oct 15, 2002 | 06:57 PM
Ratchet's Avatar
I know you have already probably checked but what do the spark plugs look like. And have you changed them in the last 20,000 kms?
Black and Oily looking ______ fowelled and not firing
Coffee collor is gooooood______ everything working right
coffee colour to yellow to whitish _____ too lean
Ric
Ghettobird52
Jul 5, 2024 11:18 PM
Infested
May 22, 2018 11:56 PM
justin57
Aug 20, 2015 07:05 PM
zeitghaist
Aug 18, 2015 07:33 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
