Third Gen Association of Ontario Regional message board for everyone in Southern Ontario and nearby regions.
Pre-bent brake Lines??
Old Oct 24, 2002 | 08:59 PM
tanager11's Avatar
Car: 91 Z28 Vert
Transmission: TKO
Axle/Gears: 3.55 10-bolt
Anyone know where I can purchase brake lines already pre-bent/flaired. I have to do some work and thought that if they are not that much more expensive it might be worth it (since I have to purchase the tools to do it too), any ideas???
Old Oct 24, 2002 | 09:27 PM
Slade1's Avatar
I usually get my brake lines from the smaller part dealers. One near me is Jon's autoparts. That's where I got mine.
They're cheap, fairly flexible and pre-flaired. You could go with the CT ones even if you knew exatcly what you wanted in size as they also have preflaired lines too with fittings.
It depends also just how far you want to go on replacing lines too though. Replacing all your lines will cost and will be a pita job to do, but buying them prebent is a waste really...
Let me guess... you got a posi rear end with higher ratio gears?
Old Oct 24, 2002 | 11:46 PM
Daz's Avatar
Daz
Car: 87 Camaro
Engine: Chevy V8
Transmission: auto
You cant buy pre-bent brake lines(not that I know of)..You can however get custom ones made up if you go to Cisco(not the computer company).Cisco makes any kind of tubing/piping for anything..lol I sound like an ad
Daz
Old Oct 25, 2002 | 09:55 AM
Slade1's Avatar
Know of a good place that sells braided lines?
I never knew about the prebent stuff for lines, I only goto GM for really really really hard to find stuff... that and when I feel like bending over...
Old Oct 25, 2002 | 10:26 AM
Stang Eater's Avatar
We stock braided stainless lines, and all the adapters you need to hook them up...come in different lengths, 90's or straight ends, most people use 3AN some use 4......as for pre-bent lines, look in the back of a rodding mag.....usually some in there, dont have one handy but I'm pretty sure there someone that advertises in GM High Tech.......not positive if they do third gens though........
Old Oct 25, 2002 | 10:29 AM
Daz's Avatar
Daz
Car: 87 Camaro
Engine: Chevy V8
Transmission: auto
Cisco MAKES them to any spec you want,they even carry Aeroquip stuff..Tell them what fluid at what pressure and theyll sell/make it for you..GM doesnt sell brake lines(except for the flex hose)..last time I checked..
FYI they sell quick release,"u-jointed" fittings too
Theyre at Dixie and 401..
Daz
Reddeath210
Oct 6, 2015 08:20 AM
Warlocksirix
Sep 3, 2015 12:26 PM
Nj1987
Aug 19, 2015 08:26 PM
Leggman1
Brakes
Aug 12, 2015 08:39 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
