Third Gen Association of Ontario Regional message board for everyone in Southern Ontario and nearby regions.
Carb question
Old Oct 26, 2002 | 04:41 PM
copperchick's Avatar
Car: 1984 Z/28
Engine: 383 stroker
Carb question
How thick is an adapter plate? I'm thinking less than an inch. Anyone know for sure?
Old Oct 26, 2002 | 05:03 PM
Daz's Avatar
Daz
Car: 87 Camaro
Engine: Chevy V8
Transmission: auto
it comes in many forms/makes and sizes..For an LG4 I would suggest either a 1/2" or 1" thick 4 hole spacer made of aluminum..Check your hood clearance
Daz
Old Oct 26, 2002 | 05:38 PM
Car: 1984 Z/28
Engine: 383 stroker
Yeah, the issue of hood clearance is why I'm asking.
Old Oct 26, 2002 | 05:58 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
I believe the adapter plates are very thin, prolly 1/4" or so.
Now, spacers are different. I had a 1" spacer and 4" air filter on my stock LG4 intake, but had to ditch the spacer and get a 3" filter when I got my new intake.
Old Oct 26, 2002 | 06:55 PM
johnyIROC's Avatar
Just to let you know. A performer RPM will NOT fit under your hood If you are planning on using an adaptor plate. Adaptor plates are never 1/4". The one I had was about 1". The performer RPM barely fits as it is. You have to use a drop-out air cleaner... this is mandatory. Also the 82-84 Z28 hood has less clearance than most because of the "fake scoops".
Your options are the following:
1. Get a carb that will bolt to the intake (Holley) and get a drop out cleaner
2. Cut a hole in your hood (Cowl)
Old Oct 26, 2002 | 07:12 PM
Car: 1984 Z/28
Engine: 383 stroker
Hi Johny. OK, I don't have a stock hood. I have an IROC hood. Long story. I don't know if there's anymore clearance under it than there would be under the stock Z28 hood. I do have a drop-base air cleaner. It drops quite a bit, so it should help.
Old Oct 26, 2002 | 07:18 PM
johnyIROC's Avatar
Even with the drop out and that hood, I'm pretty sure that it still won't fit if you are planning to use an adapter plate. The smallest plates you can get are around .75" thick. Since you are getting a new carb... I would suggest that you get a square bore holley. That will solve all your problems.
Old Oct 26, 2002 | 07:48 PM
Car: 1984 Z/28
Engine: 383 stroker
Yeah, I may have to go that route. I was just trying to determine if it were at all possible to just have my Q-jet rebuilt and use an adapter plate, thus, saving me about $400. So far, it doesn't look promising. Curses!
Old Oct 26, 2002 | 08:13 PM
Kevs87TA's Avatar
Car: 1990 GTA
Engine: L98 5.7 L
Transmission: 700R
Axle/Gears: 3.45 9 Bolt
I hate to say it, but a Performer intake would suit your needs better. It is setup to take either squarebore and spreadbore carbs, without a spacer plate. When I researched for my setup I was met with alot of obstacles. Hood clearance is a major issue unless you plan on going with a cowl induction hood. If you go with a Holley carb, do not get a dual feed, a drop base won't work with it. Holleys are also taller than your stock q-jet. Edelbrock is about the same as the q-jet. To check for hood clearance take some modeling clay and make 5 cones 2-3 inches high. Place the cones on your existing air cleaner one at each side and one on the center nut. Close the hood and open it and check the cones with a ruler. this will tell you how much room you have to play with.
Old Oct 26, 2002 | 08:27 PM
Car: 1984 Z/28
Engine: 383 stroker
Hi Kev. I did a variation on that test already. That's why I was asking about the thickness of the adapter plate. As for the perfomer RPM, I have already bought it and I got a seriously good deal on it which is largely why I bought it. I get the impression that most people think this was a bad idea. I want to make it work though. The darn thing looks so innocent sitting on our diningroom table, next to the drop base air cleaner and other goodies.
Old Oct 26, 2002 | 08:50 PM
Daz's Avatar
Daz
Car: 87 Camaro
Engine: Chevy V8
Transmission: auto
Ill trade you a Performer 2101 for it
Daz
Old Oct 27, 2002 | 01:12 AM
Kevs87TA's Avatar
Car: 1990 GTA
Engine: L98 5.7 L
Transmission: 700R
I know exactly how you feel. You should contact 88farmkid. He is a member here that attended our first Dyno Day. He was running with a Performer RPM and a Holley carb. He might be able to give you some insight as to what was needed to get it to fit. He had a 350 that kicked out 275+ RWHP.
Old Oct 27, 2002 | 03:00 PM
Car: 1984 Z/28
Engine: 383 stroker
Thanks Kev..I'm looking him up now.
How's the Mrs feeling anyway? Better I hope.
Old Oct 27, 2002 | 03:41 PM
Eric2ndGen's Avatar
I agree with Johnny's numbers on plate thickness- minimum 3/4". The point is that the plate bolts to intake using one set of mount holes- and the fastener head (usually an allen-head type bolt)has to be contained within the spacer (i.e. flush with the top mounting surface) so that carb will mount flat. Then- there has to be enough material in the spacer to hold the carb hold-down bolts so carb doesn't rip out the first time you push on it sideways (i.e. more than 3/8"). Now- add in the thickness of a carb gasket (or two- depending on how well adapter plate seals to intake on its own) ...
Old Oct 27, 2002 | 10:15 PM
383 Smoka's Avatar
Edelbrock Part #2732
1/16" Adapter Plate
Old Oct 27, 2002 | 10:27 PM
johnyIROC's Avatar
1/16" Adapter Plate
That unit is for using a square bore carb on a spread bore intake.
The one she needs is for a spread bore carb on a square bore intake. Minnimum .75"
Old Oct 28, 2002 | 11:30 AM
383 Smoka's Avatar
My bad... Hey Johnny IROC... I have the Edelbrock Performer intake, non EGR... Than I have the Performer 1406 carb... My intake is spreadbore right? My carb is squarebore... Why dont I need that 2732 adapter? My carb bolted straight to the intake... Should I have this adapter? If not, whut size spacer would u recommend... Its a 350 bored .30 over, I know it has roller rockers, performer intake, performer 600 cfm carb, hedman headers, etc... Ive been havin some carb problems and no one can seem to set it properly... Just wondering if this adapter or spacer could be the problem?
Old Oct 28, 2002 | 12:04 PM
darbleinad's Avatar
Car: 84 Trans Am
performer intakes have both the spreadbore (q-jet) and squarebore (holley, edelbrock). 600 cfm will work for the 350, although i am sure it could handle at least a 650 cfm no problem. exactly what kidns of problems are you having? i am sure a good tuning will solve most of the problems.
Old Oct 30, 2002 | 01:10 AM
383 Smoka's Avatar
When I hammer it off the line, it kinda sounds like it winds up before it moves..... I hit the pedal, seems like it sucks air, than takes off.... Theres some kind of delay.. Northern Performance tuned the carb n did my timing n said it was dead on.... But I dunno... Once I get moving it flies...
Old Oct 30, 2002 | 01:11 AM
johnyIROC's Avatar
Vacuum leak?
Old Oct 30, 2002 | 11:16 PM
Ratchet's Avatar
If your square Bore Carb has vacume secondaries you could possibly be experiencing the dreaded Quadrabog on Your non Quadrajet Carb.
Secondaries are opening too soon.
Ric
Old Oct 30, 2002 | 11:39 PM
Ratchet's Avatar
Hey Johny we just helped 383 Smoka High Jack this thread
Narly Dude:hail:
As for Your Dilema Copper Chick I am sure somebody could make you up an adaptor plate using flat Head Capscrews to attach plate to intake. Going this route I think the plate could be made as thin as 3/8".
I think somebody??? on this board with a Black TransAm has the skills and tools to do the job. I bet you could sweet talk him.
Ric
Old Oct 31, 2002 | 01:16 AM
383 Smoka's Avatar
I think yer right ratchet.... U can hear it bog.. Like i deep low sound... Can I just put in step up springs n that'll fix it?
Old Oct 31, 2002 | 01:48 AM
Daz's Avatar
Daz
Car: 87 Camaro
Engine: Chevy V8
Transmission: auto
I missed the original question..IMO an adapter plate is bad for performance as your introducing something that hinders flow(by changing the flows direction)..I would do it right and get the proper carb for it
Daz
Frozer!!!
Jan 19, 2024 04:55 PM
MustangBeater20
Oct 29, 2022 09:20 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
theurge
Aug 21, 2015 12:46 PM
redmaroz
Aug 16, 2015 11:40 PM
