Third Gen Association of Ontario Regional message board for everyone in Southern Ontario and nearby regions.
Gauge Pods
Old Nov 2, 2002 | 12:23 PM
nblanchard's Avatar
Gauge Pods
Hey guys.. where can I find some nice A-Pillar GUage Pods?
Old Nov 2, 2002 | 12:48 PM
camarokev400's Avatar
summit and jegs: i think mine was like 20 bucks for the gauge pod and it is an auotmeter. you can single or double ones im not sure if they still make the tripple one.
Old Nov 2, 2002 | 12:52 PM
another shot
Old Nov 2, 2002 | 01:46 PM
ClarionedCanuk's Avatar
I think I got a price of 38 bucks (canadian funds) for those autometers before. Not to bad.
how do you attach them? Cut a hole in factory ones and bolt/epoxy them on?
greg
Old Nov 2, 2002 | 01:49 PM
You have to remove the a- pillar from the car then you take and drill 2 big holes in the center of it for the wires to run down through then you take and drill 4 small holes, one in each corner of the gauge pod and a pillar then they give you 4 push pins that you can only use one time so make sure you get it where you want it..... it is actually really easy to install, the hardest part is running all the wires, i will be taking mine back out because i got an autometer mechanical oil pressure gauge and it is leaking inside of the gauge. Its not hard at all and i think it looks pretty slick.
Old Nov 2, 2002 | 05:07 PM
nblanchard's Avatar
Thanx man... I checked out the autometer one, just wondered if there were any 3 guage pods made from any other companies
Old Nov 2, 2002 | 10:50 PM
check out this thread.... maybe you can pm that guy and find out if he ever found one
https://www.thirdgen.org/techbb2/sho...llar+guage+pod
Old Nov 2, 2002 | 10:59 PM
STIFFLER's Avatar
Ohh I like where that Tach is... but how off are the orignal ones?
Old Nov 2, 2002 | 11:05 PM
The stock tach and the aftermarket 5 inch auto meter are within 100 rpms of each other they are pretty much the same... as for the other gauges i dont have my oil pressure or temperature hooked up to the stock gauges they are ran to my A pillar gauges, i did not want to trust the stock ones for that... ive heard some stories about camaro gauges not being very accurate.. i actually have a friend who blew up his 383 becasue someone pulled his drain plug and he didnt realize he had lost oil prussure so thats another good thing about them being right up in your face you never miss them.
RS Reaper
Oct 17, 2018 07:52 PM
apie2546
Oct 16, 2016 02:24 PM
Luigytico09
Oct 1, 2015 08:46 AM
Gordonr1973
Sep 29, 2015 11:59 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
