Any of u know anything on a Pontiac Tempest?
Car: Bonnievillie
Engine: 3.8L
Hey guys
im looking into a Pontiac Tempest car.
I dont know anything about these cars.
Gimmie some details..
I know its a 2.8Liter V6
thats about it; have any of u had them before?
Car: 1992 Camaro Z28 Anniversary Edition
Transmission: Borg Warner 5-Speed
lol don't buy one the car is garbage worst car ever made my buddy has one, his is rusted out to **** sounds like a honda and he got a license plate that said "TMPNATOR" lol
I've always had good luck with the GM 2.8/3.1 engines.
So far my family has had 4 of them:
87 Chev Celebrity (2.8 V6) - 460K before we decided not to fix a gas tank leak.
89 Chev Celebrity (2.8 V6) - 390K when it blew a valve
92 Chev Lumina (3.1 V6) - 350K when the transmission blew towing a heavy trailer
93 Pontiac Grand Prix (3.1 V6) - currently has 220K on it.
None of these cars burned much oil at all - usually about 1L between 5K oil changes.
And my current winter beater - 89 Grand Prix (2.8 V6). Has 190K on it and doesn't seem to burn oil.
As always with a GM, the little things will break. Expect alternators/rads/other little stuff to go every once in a while. Most of it isn't expensive to fix yourself.
Also make sure it does NOT have the 4 wheel disc brakes. They are a nightmare (and yes my current beater has them).
If it does make sure to get the rear calipers serviced at least once a year.
Hope that helps,
Mark
If it does make sure to get the rear calipers serviced at least once a year.Hope that helps,
Mark
Car: 1987 iroc-z custom
Engine: 355 tuned port
Transmission: 5spd baby, only way to go
Axle/Gears: 3.45
to the best of my knowledge its the family car barretta...(means that its the family version of the barretta)
runs ok, i think they are all auto...and they are good motors...just be sure not to spin the crank..(done that 2 times thus far with 2.8L motors)
if its a good price and not much has to be fixed...buy it up
iroc2nv
iroc2nv
My buddy owned a Tempest... what year is the one you are looking at?
Things to look for in a Tempest...
- Water leaks through the firewall, puddling on the passenger or drivers floors.
- As for rust, look at the rockers, door cills, and hood.
- Give the car quick jolts of acceleration to check for bad motor mounts.
- Coil packs like to go on those cars as well.
- Injectors are also a weak point.
- Then the already mentioned stuff that GM cars always need replacement.
- I highly doubt your car has 4 wheel discs, because Tempests didn't come with them in the early years, or in the later year, as far as I know.
- When you hear it run.. make sure you hear running when its cold, this is when you'll hear any engine knocks, or notice bad coils and injectors
Car: Bonnievillie
Engine: 3.8L
Well the guy sold it anyways..
it was 750 bux
cert. and emission
and the body was in good shape, except for a small dent in the front left fender.
it was 750 bux
cert. and emission
I had an 89 Beretta until 99. Decent car, again with the alternators. A friend at work has the Corsica. His is manual. He likes his. The military used them for "Staff Cars" until about 3 years ago. But yeah, disposable cars. GMs answer to the Tempo/Topaz line. For 750 cert and e tested. You could do worse...
