Third Gen Association of Ontario Regional message board for everyone in Southern Ontario and nearby regions.
A serious engine swap on ebay...
Old Dec 4, 2002 | 06:24 PM
Cruz'N Bruz'R's Avatar
Car: 87 Iroc Z
Engine: 383ci.
Transmission: WC-T5
Check out this ebay item...
LT5 for sale on ebay
This would be perfect for you 15s guys that want to do a killer swap and shut us all down.
Old Dec 4, 2002 | 06:33 PM
johnyIROC's Avatar
Re: A serious engine swap on ebay...
Humna humna lalallalallalal :hail:
Old Dec 4, 2002 | 07:01 PM
Acceld Z's Avatar
Car: 1992 Z28
Engine: 355
I hope it comes with a sawzall. You'd need it.
Old Dec 4, 2002 | 07:34 PM
88redxtsy's Avatar
All I want for Christmas is ..........................THAT!!!!!!!!!!!:hail:
Old Dec 4, 2002 | 07:41 PM
darbleinad's Avatar
Car: 84 Trans Am
yep,
that would do it. what do those put out stock? 390 HP? how about torque?
there is also a nice 70-74 cuda in the background there.
Old Dec 4, 2002 | 08:32 PM
SBlackfoot's Avatar
Car: '90 Trans Am GTA
Engine: LB9
Axle/Gears: 2.73's
So who's headed to Seattle and wouldn't mind picking something up for me?
Screw the GTA, that would fix the problems I've been having with my Jimmy quite nicely.
Old Dec 4, 2002 | 08:55 PM
Stang Eater's Avatar
Hey Acceld,
You could be correct, but I'm going to doubt that youd need one....there's a car on the camaro legends tour with an LT5 and ZF6 spd in it, VERY nicely installed(shouldbe since it was done by Chevy lol).....I saw it in person at the camaro nationals a couple of years ago and it was tight, but didnt appear to be cut at all....
Old Dec 4, 2002 | 09:23 PM
johnyIROC's Avatar
Originally posted by Stang Eater
Hey Acceld,
I think think you are right... it was designed to go into a C4... so it can't require that much modification. I know the ZR1s were a little wider at the back, but I don't think the engine compartment was any different.
Old Dec 5, 2002 | 05:14 PM
Car: 87 Iroc Z
Engine: 383ci.
Transmission: WC-T5
The LT5 was the same engine unmodified from 90' thorugh till 95'. In 95 it was rated at 405hp, but many dyno's haven proven they put that power to the wheels completely stock.
Old Dec 5, 2002 | 05:41 PM
Acceld Z's Avatar
Car: 1992 Z28
Engine: 355
That LT5 thirdgen has had it's crossmember removed and replaced and has had the sides of the strut towers shaved off. The GM raceshop also moved a portion of the firewall back. The LT5 is very wide and the block and oil pan where designed to allow it to sit low in the chassis. It wouldn't be an easy install but the results would be well worth it.
Old Dec 5, 2002 | 05:44 PM
Acceld Z's Avatar
Car: 1992 Z28
Engine: 355
They added 4 bolt mains and started porting the injector housings in '93. The '93+ cars weren't any quicker because GM started adding crap to the 'vette to keep the C4 platform attractive.
Old Dec 5, 2002 | 06:21 PM
Kevin Vandevenne's Avatar
Car: 87 IROC
An LS1 would probably drop in alot easier than the LT5, and offer clost to the same performace, for alot less.
But the LT5 does have the cool factor department wrapped up.
Old Dec 5, 2002 | 06:43 PM
I stand corrected!!
Old Dec 6, 2002 | 12:43 PM
Corbi_85-IROC's Avatar
Car: 85 iroc z
Engine: LG4 :(
Transmission: 5 speed
Here is the infamous Jon Moss LT5 equiped Thirdgen camaro.:hail:
Old Dec 6, 2002 | 04:23 PM
chevypower91's Avatar
Car: 1991 Camaro Z28
Engine: 305 cid
Axle/Gears: Posi/3:42
ZR1 Camaro
You should see and hear that car go.
Man oh man!
Old Dec 6, 2002 | 04:24 PM
Acceld Z's Avatar
Car: 1992 Z28
Engine: 355
Gayest paint job ever. Man, I want some R15's
Old Dec 7, 2002 | 12:54 AM
tanager11's Avatar
Car: 91 Z28 Vert
Transmission: TKO
Axle/Gears: 3.55 10-bolt
I second the notion that the paint is Gay!
Old Dec 7, 2002 | 11:47 AM
Car: 85 iroc z
Engine: LG4 :(
ya the paint may not be your or my cup of tea but you still gotta admit the car with that drivetrain is still pretty sweet.:lala:
Frozer!!!
Jan 19, 2024 04:55 PM
camaro11j
Sep 19, 2018 08:49 AM
theshackle
Mar 5, 2017 06:37 PM
sreZ28
Aug 14, 2015 07:48 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
