Third Gen Association of Ontario Regional message board for everyone in Southern Ontario and nearby regions.
Engine detailing question..
Old Dec 16, 2002 | 07:51 AM
MR. JORDAN's Avatar
I'm at the point now where i can Paint my heads and block. What is the best way of doing this? Also what is the longest lasting High Temp paint? I really don't want to have to pull the motor again just to paint it anytime soon. Wire brushing it sould be fine enough to clean/prep it right?
Who has done this with good results? Tell me your story....
Old Dec 16, 2002 | 08:24 AM
Cruzin Kaz's Avatar
Car: 85 Monte Carlo SS...
Engine: T.P.I L98.
Transmission: TH350
Axle/Gears: 3:73 Posi
Hey Jordan. Are the head off the engine??? Much easier if so. Yes a wire brush will work as long as it isn't really bad. The real thing to worry about is grease and oil. I'd use some paint prep or something along that line before you do any painting. The paint I have always used is made by Duplicolor (engine enamel), works great! And last long. I then coat it with Dupilcolrs ceramic clear coat good to 500 degrees, gives it a great looking shine to boot. The main thing is make sure the surface is clean of any loose paints and or greases and oils and you'll be laughin.
HTH
Keiran
Here is mine that I did, excuse the coolant stains, blew the rad at the track.
Old Dec 16, 2002 | 10:18 AM
Idlehands's Avatar
Car: 1985 Trans Am
Transmission: 5 Speed
WOW Kaz......excellent job
Old Dec 16, 2002 | 10:32 AM
Cruzin Kaz's Avatar
Engine: T.P.I L98.
Transmission: TH350
Thanks. It's what I do best. I love making cars look like they belong in a showroom. But in the Monte's case, I want to goes fast as well as look good. Well I want to go faster first.
Old Dec 16, 2002 | 12:49 PM
Paul_Hughes_87 T/A's Avatar
Car: Chrysler 300c
Engine: 5.7L Hemi
Transmission: 5spd auto
Axle/Gears: 2.89
Kieran how can I get off a piece of brown bird $hit off my hood? It will not wash off.
Old Dec 16, 2002 | 02:50 PM
Cruzin Kaz's Avatar
Engine: T.P.I L98.
Transmission: TH350
Well what do you mean it won't wash off?? The stain itself or the actuall bird crap won't come off. The only real thing you can try to do is, let it get soaked, leave a damp rag sitting on it, in your case a hot damp rag, hopefully this will loosen it up for you. That's the bad thing about bird crap...you "Must" get it off as soon as possible. If you leave it sit there and it bakes in even the slightest amount of sun, your gonna leave a mark. Like I said hopefully that will do it for you , but you will probably need to take some kind of light compound or a good wax to get rid of the scratches you are going to make. Yes, there is no way to avoid some minor scratching now. Hopefully it hasn't done too much damage, but your car's white anyway so it may no show up all that bad.
HTH
Keiran
PS. If that doesn't work for you , you could try a bit of gas line anti-freeze and wipe it carfully with a rag. Again, this will most likely leave some light scratching. Gas line anti-freeze also works well at removing tar, tree sap and old stuck on bugs. But will require some polishing and waxing, due to the fact you just removed any waxes and polishes, and left a few light scratches while you were at it.
Old Dec 16, 2002 | 04:24 PM
Cruz'N Bruz'R's Avatar
Car: 87 Iroc Z
Engine: 383ci.
Transmission: WC-T5
I've always used a wire brush, then some paint thinner or such to get rid of grease stains, then the regular old CT engine paint in a can. Longest it's been on a block that I know of has been 9 years untouched, and no chips or faded areas.
Old Dec 16, 2002 | 05:17 PM
DABE's Avatar
my engine builder used an epoxy on it...looks killer...and he said it should last a lonnnnngg time...its thick too...very durable...
gotta love a 400+hp 357sbc....
Old Dec 18, 2002 | 08:00 AM
MR. JORDAN's Avatar
Well i used the CT style black engine paint for a base coat yesterday and looks pretty good. Now I'm gunna find some Yellow High heat paint for a top coat. This way the block will match the car and will have good coverage. The ****ty thing is, CT Don't make the paint in Yellow, so i'm gunna have to mix two different brands. I just hope chemically the two are compatible.
Afer all the paint is on I'll put on the chrome and take some pics for you guys...
Old Dec 18, 2002 | 12:47 PM
Idlehands's Avatar
Car: 1985 Trans Am
i herd that WD40 does wonders without damaging the paint is this true?
Old Dec 18, 2002 | 12:50 PM
Cruzin Kaz's Avatar
Engine: T.P.I L98.
Transmission: TH350
I don't think it will hurt the paint really but any and all dirt and dust will stick to it with ease. I wouldn't put that on it anyway. I know people who use to use WD on oxidized paint. LOL! it kinda worked I guess but WOW here comes the dust. To each their own, but I wouldn't.
Old Dec 27, 2002 | 11:58 PM
bluedude22's Avatar
Car: 87 Trans Am
Engine: 355ci
Transmission: w/c T5
just use a cople cons of brake ckeaner to get all the crud off the block then paint!
Old Dec 28, 2002 | 12:51 AM
MR. JORDAN's Avatar
Not a bad idea dude! Just a quick question though. Were you like Fuc<x>ked up while typing that post?
Old Dec 28, 2002 | 02:25 AM
easySPEEDcamaro's Avatar
Car: 1992 Camaro Z28 Anniversary Edition
Transmission: Borg Warner 5-Speed
lol u know what's even more weird, when i read his post i didn't even notice the spelling mistakes, i'm getting old or something. it's not the first time i've done it.
Old Dec 28, 2002 | 08:27 AM
Cruzin Kaz's Avatar
Engine: T.P.I L98.
Transmission: TH350
Brake CLEANER..not brake fluid. Brake cleaner will work great.
Old Dec 28, 2002 | 09:13 AM
bluedude22's Avatar
Car: 87 Trans Am
Engine: 355ci
ya I just got back from a party.lol
Vintageracer
Jan 10, 2020 05:33 PM
gta90
Sep 15, 2015 04:00 PM
Polo Z03
Sep 10, 2015 06:43 PM
theurge
Aug 21, 2015 12:46 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
