Third Gen Association of Ontario Regional message board for everyone in Southern Ontario and nearby regions.
LG4 Engine
Old Jan 9, 2003 | 03:48 PM
88redxtsy's Avatar
LG4 Engine
Look! A tech question finally I was reading my firebird book for thirdgens and noticed that from 82 - 87 (I might be off here) the 305, 4 barrel carb engines were making 190hp and 250tq. Is this right! with a 5speed! Wow! call me nieve.....
Anyway.....is this known as the LG4 engine? or is this a different engine?
Old Jan 9, 2003 | 04:09 PM
85_ZED28's Avatar
Car: '85 Z28
That would be the L69 engine, not an LG4
Old Jan 9, 2003 | 10:59 PM
Kevs87TA's Avatar
Car: 1990 GTA
Engine: L98 5.7 L
Transmission: 700R
Axle/Gears: 3.45 9 Bolt
The LG4's were rated at a whopping 155 HP, hence the desire to upgrade these boat anchors. Palric sent me a page from a site where a couple guys took an LG4 from a Camaro and did some simple bolt-ons and a XE cam and they ended up at ...get this...324 HP I would like to get close to that as I can. I still have a long way to go With the new headers and cat-back, we'll see at Dyno Day, how much farther I have to go.
Old Jan 10, 2003 | 07:52 AM
tanager11's Avatar
Car: 91 Z28 Vert
Transmission: TKO
Axle/Gears: 3.55 10-bolt
those new headders and cat back on that LG4 of yours Kevin will certainly help out with the numbers....for some reason I thought you also had a Cam swap in mind for the winter?
Old Jan 10, 2003 | 08:03 AM
George's Avatar
Car: 83WS6TA
Engine: ZZ4
Transmission: TH350C
Axle/Gears: 3:23
Did the later LG4s get flat top pistons?
Old Jan 10, 2003 | 08:26 AM
Kevs87TA's Avatar
Car: 1990 GTA
Engine: L98 5.7 L
Transmission: 700R
I never said it wasn't , then again I never really said what I have planned. I guess we'll just have to wait for Dyno Day.
Old Jan 10, 2003 | 08:28 AM
Kevs87TA's Avatar
Car: 1990 GTA
Engine: L98 5.7 L
Transmission: 700R
I would think they did. They upped the compression ratio in 1987 to 9.3 and they also had the newer heads with the centerbolt valve covers.
Old Jan 10, 2003 | 08:39 AM
tanager11's Avatar
Car: 91 Z28 Vert
Transmission: TKO
Geez....you really are keeping that thing under wraps till dyno day eh Kevin.......regardless I heard thru a couple of memeber that LG4 of yours was making a surprise appearance at the Toronto Boat show this weekend....after all it is a boat anchor so it should fit right in! Ha ha :lala:
Regardless, in all honesty I am interested in seeing what gains you do get from your mods next year at the dyno day.
Old Jan 10, 2003 | 09:07 AM
Kevs87TA's Avatar
Car: 1990 GTA
Engine: L98 5.7 L
Transmission: 700R
Hahaha...good one. After all I am running a Marine type Holley...
We'll see how that peanut cam of yours does at Dyno Day. Just make sure you put an atleast a dollars worth of gas in before you come down. That should do you the trip down, back and then some. J/K
Old Jan 10, 2003 | 09:18 AM
88redxtsy's Avatar
L69.....I keep hearing of the LG4. Were the L69 engines rare or something? Does anyone on the board have an L69 engine in their car? with a manual transmission? I'm sure that thing could move. Faster than my TPI.
Old Jan 10, 2003 | 09:51 AM
Cruzin Kaz's Avatar
Car: 85 Monte Carlo SS...
Engine: T.P.I L98.
Transmission: TH350
Axle/Gears: 3:73 Posi
I had the L69 in my Monte and it was no comparison at all to my TPI that I have in it now. Just my .02
Old Jan 10, 2003 | 10:02 AM
KWF's Avatar
KWF
l69 vs lg4
Wasnt' the primary difference the dual snorkel air intake?
Old Jan 10, 2003 | 10:33 AM
George's Avatar
Car: 83WS6TA
Engine: ZZ4
Axle/Gears: 3:23
I don't have a list of the differences but it was more than just the snorkle. Pistons in the early LG4s were dished v. flat tops in the L69. It seems though that the LG4s did get better in later models.
Old Jan 10, 2003 | 12:19 PM
Daz's Avatar
Daz
Car: 87 Camaro
Engine: Chevy V8
Transmission: auto
different cam
Daz
Old Jan 10, 2003 | 01:03 PM
Kevs87TA's Avatar
Car: 1990 GTA
Engine: L98 5.7 L
Transmission: 700R
Here is a link for all your engine specs. The L69 was available up to 1986 and was a 4 bbl carb/HO. It was discontinued in 1987.
http://www.transamgta.com/EngineSpecs.html
Not your everyday factory LG4
Old Jan 10, 2003 | 01:33 PM
KWF's Avatar
KWF
I dont' believe that engine bay is of your car Kev.
I mean... where's all the green coolant spraying out burning people?
Old Jan 10, 2003 | 06:12 PM
tanager11's Avatar
Car: 91 Z28 Vert
Transmission: TKO
I was thinking the exact same thing KWF!
Old Jan 10, 2003 | 06:47 PM
George's Avatar
Car: 83WS6TA
Engine: ZZ4
Axle/Gears: 3:23
That t-junction spliced into that hose there looks like it's about to let go.
Maybe shouldn't go on any long trips until you get that fixed.
Old Jan 10, 2003 | 07:20 PM
Daz's Avatar
Daz
Car: 87 Camaro
Engine: Chevy V8
Transmission: auto
LOL it did let go..
Daz
Old Jan 10, 2003 | 10:34 PM
Kevs87TA's Avatar
Car: 1990 GTA
Engine: L98 5.7 L
Transmission: 700R
Hahaha...don't you worry, all new heater hoses are the first thing that I plan on doing before spring. I will not have a repeat of last summer, this year. I actually want to clean up that bay by getting rid of the aircon, since it doesn't work anyways, and rerouting the heater hoses and some wiring. I also want new valve covers. I was in Buffalo and at Auto Zone they had a set for centerbolt heads for $39.99. They were ribbed, but other than that, they were plain Jane, which suits me fine. I just wish I had picked them up.
Old Jan 11, 2003 | 12:22 AM
Daz's Avatar
Daz
Car: 87 Camaro
Engine: Chevy V8
Transmission: auto
make sure theyre real valve covers not just 'skins" or valve cover covers..Paradi$e Alley sells just the cover..It goes on top of the original valve covers..
Daz
Old Jan 17, 2003 | 06:28 PM
Hawk92z-TDZ's Avatar
Car: 92Z28, 99SS, 83Z28 & 86GTA
Engine: 421, LS1, 327Turbo & 383
Transmission: T-56, 4L60E, T5 & 4L60
Axle/Gears: 4:10, 3:42, 2:73 & 3:27
Dyno day???
I'd luv to get my boat dyno'd
Old Jan 17, 2003 | 11:19 PM
Kevs87TA's Avatar
Car: 1990 GTA
Engine: L98 5.7 L
Transmission: 700R
Originally posted by Hawk92z-TDZ
Dyno day???
If you are interested in Dyno Day, I will be posting the date for the spring one, on this board. It is located in Kitchener. It is open to the members of this board only, and is first come, first serve. The cost is usually around $45.00. It depends on how many people we have and what the shop is charging. We usually book it for 4 hours. Keep your eyes on the board in the next couple of months. I will book it for around May.
Old Jan 18, 2003 | 12:30 AM
tanager11's Avatar
Car: 91 Z28 Vert
Transmission: TKO
It is a great time...I didnt even run my car last time, but I still had a great time just hanging out.
Kevin...needless to say when this does go on again this year I will be there for sure!
Old Jan 18, 2003 | 11:58 AM
I will defenetly try to be there Sounds fun.
Old Jan 18, 2003 | 06:33 PM
LG4
Z28 engine options
82 were the LG4 rated at 145HP and the LU5 rated at 165HP
83 were the LG4 @ 150HP, LU5 @ 175HP & the L69 @ 190HP
84 were the LG4 @ 150HP, L69 @ 190HP
85 were the LG4 @ 155HP, L69 @ 190HP & LB9 @ 215HP
LB9 being the TunePortSystem
86 were the LG4 @ 165HP, L69 @ 190hp & LB9 @ 190hp
Yes the LB9 V-8 dropped to 190HP but its torque rose to 285lbs
87 were the LG4 @ 165HP, LB9 @ 215HP & L98 @ 220HP
The L98 TPI 350 is also known as the B2L
88 the LO3 @ 170HP, LB9 @ 220HP M/T 195HP A/T & L98 230HP
89 were the LO3 @ 170HP, LB9 @ 230HP, L98 @ 240HP
90 were the LO3 @ 170HP, LB9 @ 230HP, L98 @ 245HP
91 were the LO3 @ 170HP, LB9 @ 230HP, L98 @ 245HP
92 were the LO3 @ 170HP, LB9 @ 230HP, L98 @ 245HP
Thats right out of a book, I dont know Y but it also says the 1990 350 TPI L98 Iroc is the fastest of the 3rd Gens. Weight maybe?
Old Jan 18, 2003 | 11:49 PM
FastEddy85z-TDZ's Avatar
Dyno day???
I would luv to dyno my car also
Old Jan 19, 2003 | 12:14 AM
Kevs87TA's Avatar
Car: 1990 GTA
Engine: L98 5.7 L
Transmission: 700R
With all the new guys on the board, I might try and see about a full day booking, depending on how many actually want in. It's either that, or we tack on a couple of hours. We'll see when the time comes.
Old Jan 19, 2003 | 08:19 PM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
Engine: 5.7L EFI LTR setup
Transmission: T-5 World Class
i am sooooooooo in !!!!!!!!
btW those figure up there regarding the LB9 are true but ....the 230 hp was the "Dual cat " option....... with the single ( mine ) it was 220 hp just figured I'd help
I can't wait to dyno ( if I can come ). It sounds like a wicked day !!!
Old Jan 19, 2003 | 10:37 PM
LB9
When it came to the LB9, not gunna argue, the book made it all very hard to follow at the 88 and up point, they couldnt put it straight and easy like i tried too It had listings for Auto trany vs Stick and with dual cats and with out and some performance axil thing which brought the LB9 total to 235HP Stick with Dual Cats, and loaded with everything, for 89. Yet 92 was listed at only 230HP with all the options.
92 quote right from the book.
""Beneath those hood bulges sat either the familiar 5.0l or the Corvette derived 5.7l powerplant. The smaller engine was rated at 170HP with TBI (code LO3), or 230HP with the TPI setup (LB9) and performance axle (205HP without). That performance ratio cost as much as $675.00 extra, in a package that included a dual cat exhaust system, bigger brakes, aluminum dravshaft, special shocks, and more.""
But then again it also says the 90 350 TPI IrocZ is the fastest 3rd Gen, and i would of thought the 91 or 92 would of been the same speed at least or tuned to go abit faster.
Old Jan 22, 2003 | 06:38 PM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
That was the 1LE option package ...... foglamp deleat, disc brakes , aluminum driveshaft ( I want one soooo bad ), and I think that is it .... not tooo sure though
Auto was 195 w/auto 220 manual , 230 with dual cats
Old Jan 23, 2003 | 12:30 PM
Yah, the book says 89 and 90 were 195 auto but that the 92's were 205 auto. A friend/mechanic told thats because in 92 they were all dual cats. True??
Old Jan 23, 2003 | 07:31 PM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
hmmmm That is a good question ....I'll try and find out
Old Jan 30, 2003 | 09:04 PM
IROB's Avatar
Car: '83 Z28
Engine: LT1 (in progress)
If you ordered the G92 performance option, you got the dual cats, better(?) 9-bolt rear end, etc. If you spec'ed your car without A/C, the 1LE option would be added as well. As far as differences between LG4 & L69, the L69 had a higher compression ratio (9.5 vs. 8.6), higher lift cam, dual snorkel air cleaner and a better flowing exhaust.
Old Feb 3, 2003 | 11:30 AM
icebird_1981's Avatar
lg4 did make 190hp but it is the HO engines.
Old Feb 3, 2003 | 01:07 PM
Lg4 did Not make 190HP that was the L69 and yus the L69 was the HO
Old Feb 3, 2003 | 09:36 PM
oh my bad your right i just assumed that if it was a 4bbl 305 that it was a lg4, learned something new today, thanks.
Old Feb 4, 2003 | 02:44 AM
no prob, learned alot here myself.
RazorN8
Jan 7, 2022 11:44 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Reddeath210
Oct 6, 2015 08:20 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
