does the 305 weigh more then the 350?
Not really... most small block chevys are all around the same weight. If it did weight more or less, it would be only a few pounds off of what a 350 would weigh.
Car: 90 IROC 5.7 hardtop
Transmission: T5 swap
Axle/Gears: Yup -- they still work
nope
No the 305 weighs less because it has less HP and torque.
Ok just kidding.
Roughly 3.76 inch bore vs. 4 inch bore means that much difference in core metal plus pistons different size. More metal in smaller bore more piston in 4 inch bore. They probably weigh within a few pounds of each other (305 vs. 350) or a few kilos for those of you born after Led Zeppelin was formed.
RP.
Ok just kidding.
RP.
ambainb
Apr 25, 2016 09:21 PM
