Anybody have any "E.T" goals for this summer?
Car: 1992 Z28
Engine: 355
What are you hoping to run this summer? I don't even know if i'll have the car on the road. If I do I just hope to be quicker than last year. I'd like to find my missing MPH somewhere and then get some traction. I'm hoping for a 15.0-15.4 with my new truck.
Car: 92Z28, 99SS, 83Z28 & 86GTA
Engine: 421, LS1, 327Turbo & 383
Transmission: T-56, 4L60E, T5 & 4L60
Axle/Gears: 4:10, 3:42, 2:73 & 3:27
14's
I hope to get at least low 14's this year. But my cars never been down the track so I really got no clue how it will run. I sure got alot of chalanges now though.
Looking forward to see'n how I do. I am even gunna tape the runs.
Car: 1990 Iroc Z Convertible
Engine: LB9
I don't plan on taking the Iroc out to the track but I want to take the LSS out. I hope to run a mid 14 with it, I really don't know what it'll do, I 'm just basing it on what some of the GTP guys have done considering their mods.
Car: 1991 Camaro RS
Engine: 406
Axle/Gears: 3.42s
I'd like to see my car get into the 15's also after some suspension work and a rear end swap. I'm not gonna really bother with any motor work tho as all my pennies are going into the jar for a much bigger cookie
EDIT: Actually I probalby will add a cat-back and have already started to do up the ignition a little... basically I'll do anything that I can swap directly over to a bigger motor and will need starting out for things to run well.
Car: 91 Z28 Vert
Transmission: TKO
Axle/Gears: 3.55 10-bolt
I am aiming for high 14's this year....I have a couple of "little" tricks planned, hopefully i get them all in before the year is over!
Car: 1991 Z28 Camaro
Engine: 5.7
Axle/Gears: 3.23 For Now
I'm not sure what my car can do..never had it at the track....but VERY high 13's would be nice.... (1991 Z28 5.7 L98) BBK/Edelbrock 52MM TB, TB bypass, 3 inch cat back, 80 series
Flowmaster, 3 inch electric exhaust cutout, MSD-6A ignition, JET HOT CoatedEdelbrock TES Headers, RAM AIR Boxes, K&N Airfilters...
Car: 84 Trans Am
low 13s are the goal here and if that goes well and i can get some traction and good 60 fts...maybe very very high 12s, like 12.99. but thats pretty ambitious. so low 13s will be fine.
Car: 1990 GTA
Engine: L98 5.7 L
Transmission: 700R
Axle/Gears: 3.45 9 Bolt
I am pretty certain that I will be breaking the 18's this year, I hope for a personal best of 17.99...lol, in my mini van!!!:D
As for the TA, I will be happy to get anywhere from mid 16's to mid 15's. Being as I have never taken the TA down the track, I don't know if I'm being optimistic or pessimistic.
Car: 1992 Z28
Engine: 355
Originally posted by easySPEEDcamaro
ET COME HOME!!
ET COME HOME!!
Car: 1992 Z28
Engine: 355
Originally posted by Slade1
Tanager... prepare yourself... I'm on mod break for 2 weeks mwa ha ha ha ha ha ha....
The preceeding was sarcasm. Mod what ya got.
Car: 1992 Z28
Engine: 355
Car: 91 Z28 Vert
Transmission: TKO
Slade...as for your "prepare yourself" comment..sounds like you have some deep pockets this winter...ha ha...regardless I would love to see one of the TBI guys break into the 14's.....although to be quite honest I am not sure as to if I will still be running a TBI...
Car: 91 Z28 Vert
Transmission: TKO
Stiffler....I say stick with that 305 on steriods you got....I dont know how....but it seems to put up some decent numbers.
Car: 85 Monte Carlo SS...
Engine: T.P.I L98.
Transmission: TH350
Axle/Gears: 3:73 Posi
Anything faster then my only run last year!
I'm pretty sure 14's at least, but who know's?? May run a 13, and may run a 15. Have to wait and see. Traction is my main problem to deal with this year. 2.4 60's just won't do with a TPI. Need to do some suspension work and get me a mini spool and some slicks. That should bring down that 60' a good bit.
I'm pretty sure 14's at least, but who know's?? May run a 13, and may run a 15. Have to wait and see. Traction is my main problem to deal with this year. 2.4 60's just won't do with a TPI. Need to do some suspension work and get me a mini spool and some slicks. That should bring down that 60' a good bit. Last edited by Cruzin Kaz; Mar 8, 2003 at 05:54 PM.
Mini-Spools are strictly a low-budget bracket car option in my opinion.
There is no reason why a good posi wont get both your tires movin unless you have too many ponies then its upgrade time.
my 3800lbs car & driver went 1.73 60-ft's on a stock rearend. It's a 10 bolt 8.5", but the posi is the same type as your 3rd gen would be.
Engine: T.P.I L98.
Transmission: TH350
Don't own a 3rd gen. Own a 85 Monte SS with a L98, TH350 a 3:73 gear. The trans has a 2800 stall in it right now, but I am looking at installing a Lt4 hotcam, and port and polish + gasket match. Siamese the intake and some SLP runners w/24#injectors. What would you suggest a good stall would be with this setup?? You seem to know your Turbo trannies. Any suggestions???
Well as far as the stall I think the LT4 Hotcam has what ~224 deg duration?
Your 2800 stall is probably right there with what you'd need. I dont know the exact cam specs but if you post the exact motor specs (compression, cubes, intake, carb/induction, cam specs, cylinder heads, exhaust specs, gear ect) i could give you a good opinion on what stall would probably generate a good 60-ft with traction.
I just noticed you have pretty much a stock TPI with the exception of Port & polish & some runners.
Figuring your going to max the HP output by the revs u can put to use (under 5800 i assume) then i would keep the 2800. (if it's a true 2800, by this i mean stalling at 2800 & a 10" converter)
Engine: T.P.I L98.
Transmission: TH350
Pretty much everything is in my prior post, I will be having the L98 heads machined for 2.02 and 1.6 valves. with a 10:1 ratio. 1.6 roller rockers and LT1 valve springs. Off hand I am unsure of the complete specs on the LT4 cam. If you can think of anything else jsut say so...
Engine: T.P.I L98.
Transmission: TH350
Here are those cam specs.
12551142 Hyd. Roller - 203/210 - .476/.480 - 115.5 - 96 350 LT4 w1.6 roller rockers
Thanks,
Cruzin................
Thanks,
Car: 1992 Z28
Engine: 355
Those are the production LT-4 cam specs. The Hotcam is........
218/224 .525/.525 with a 112LSA
I'd stick with the 2800.
ACCELD hit it right on the nose.
I agree & think that 2800-3000 stall would be a good choice.
Just make sure your converter is stalling at this. If it's an 11" i would chuck it. If it's a 10" it's more likely to stall at it's desired point.
Car: 1992 Z28
Engine: 355
Originally posted by trigger GTA
14.5 i dont think i will be any faster than that
14.7-14.9 i will be happy, orinally i was looking for 14.5 this spring but seeing that i dont have the money for the slp runners cause i want new brakes.
last year i ran a 15.1, before i go this year im installing a jacobs pro street ignition system, with msd wires i believe, and also a hooker catback, thanks to gerry,
but the first thing that has to be done is getting the car back on the road
Car: 1992 Z28
Engine: 355
Originally posted by johnyIROC
If you can't squeeze off a 12 on the spray... it's time to give up. Or buy ET streets.
Car: 92 TA vert
Originally posted by Acceld Z
Scott, why must you turn this into a house of lies?
this way if i run that time so be it... and i will not be let down. and if i run a little faster.... then great.
Car: 1989 IROC-Z
Engine: 5.7L EFI LTR setup
Transmission: T-5 World Class
ya I get it
Xtra weight = NOS Wet kit
= added supercharger
LOL ..... sometimes a " little " weight is a good thing
Originally posted by Homer2
i'd like to see 13's . . .
might be asking a lot of a few mods - but ever the optimist
Ran a 14.0@99 with radials & a 2.0 60-ft.
weird huh?
my 355 i stock heads - unknown (oversized i suspect) cam,
2.72 no posi, th350 stage 1 kit, stock stall, performed intake, holley 600, radials -
getting 2.3x 60ft but 14.5 at 99.xx
very strange - seems to really pull right now in the mid range
if i move to the xe262 cam, plop in the posi and 3.23's - i should definitely get better 60's, faster first half of the track - but i wonder what it will do to the top half ,
i could see better times and less mph?
Car: 87 Camaro
Engine: Chevy V8
Transmission: auto
weird huh?
weird huh?
Daz
