Third Gen Association of Ontario Regional message board for everyone in Southern Ontario and nearby regions.
Ahhahaha I almost burnt my car down!
Old Jun 24, 2003 | 03:26 PM
easySPEEDcamaro's Avatar
Car: 1992 Camaro Z28 Anniversary Edition
Transmission: Borg Warner 5-Speed
Let's just say I have a fuse... and I have my alarm plugged into it, my led scanner, and my power seat...
Anyhow, today the fuse burnt out and if any of you saw my old wiring job you'd think I was crazy.
I decided to clean it up a bit. So I stopped at Radio shack and bought some electrical tape and a new fuse...
Went to plug everything in suddenly SMOKE EVERYWHERE!!!!
the wire was glowing red in one part too, so i immediately pulled out the fuse and burnt my fingers while I was doing that (nothing too major)...
In any case, until further notice I unplugged my seats and scanner...
Old Jun 24, 2003 | 03:33 PM
Paul_Hughes_87 T/A's Avatar
Car: Chrysler 300c
Engine: 5.7L Hemi
Transmission: 5spd auto
Axle/Gears: 2.89
Re: Ahhahaha I almost burnt my car down!
Theres your problem you halfassed the fix
Old Jun 24, 2003 | 07:58 PM
Cruzin Kaz's Avatar
Car: 85 Monte Carlo SS...
Engine: T.P.I L98.
Transmission: TH350
Axle/Gears: 3:73 Posi
Re: Re: Ahhahaha I almost burnt my car down!
Yeap heat shrink and solder are the only way to do electrical. I don't even like to use but connectors and such.
Old Jun 27, 2003 | 06:36 PM
SBlackfoot's Avatar
Car: '90 Trans Am GTA
Engine: LB9
Axle/Gears: 2.73's
Old Jun 28, 2003 | 07:27 AM
iroc2nv's Avatar
Car: 1987 iroc-z custom
Engine: 355 tuned port
Transmission: 5spd baby, only way to go
Axle/Gears: 3.45
alex,
you may be good at some things...but electronics you arent..
if you need help with something im sure that someone on here will help you..wed all rather help then see you kill yourself or lose your car because you were unsure of what to do..
iroc2nv
Old Jun 28, 2003 | 11:18 AM
Cruz'N Bruz'R's Avatar
Car: 87 Iroc Z
Engine: 383ci.
Transmission: WC-T5
Your witre started glowing red and smoking because it is not physically large enough of a witre guage to support the current needed. You should break up your circuits, 1 circuit for the alar and scanner, one for your power seats, fuse BOTH of them separately, and make sure the main power wire feeding both circuits is large enough to handle the total current. 10AWG wire should be good.
Old Jun 28, 2003 | 08:45 PM
SBlackfoot's Avatar
Engine: LB9
Axle/Gears: 2.73's
Odds are he didn't have everything turned on when he first hooked them up (no comment if they were), so if the wire immediately started to burn the insulation off he must've shorted it out somwhere. Assuming he still had a fuse inline at this point with a reasonable amperage it should've just popped the fuse, unless the wire was WAY too small (numerically large) of a gauge.
Old Jun 28, 2003 | 09:43 PM
Car: 87 Iroc Z
Engine: 383ci.
Transmission: WC-T5
Basically, the wire size has to be large enough to handle whatever current your fusing for. Take your fuse amperage, and multiply it by 125%(at least) to be sure.
Old Jun 28, 2003 | 10:26 PM
it's been working fine all together for a year
but no doubt the wire got fried...
Old Jun 28, 2003 | 10:31 PM
Car: 87 Iroc Z
Engine: 383ci.
Transmission: WC-T5
It could work fine for five years till you get the one shorted wire, and it burns down while parked and your at the mall or something...
Old Jun 28, 2003 | 11:12 PM
SBlackfoot's Avatar
Engine: LB9
Axle/Gears: 2.73's
Like I said, it's more likely it was a short rather than the devices themselves drawing too much current through inadequate wiring. The fact that it happened just as he hooked up to the power source further backs this theory. Still, the fuse should've blown before the insulation melted unless it's rated freakishly high.
maroe624
Apr 16, 2017 08:29 AM
Reddeath210
Oct 6, 2015 08:20 AM
Linson
Aug 21, 2015 02:12 PM
kyleb24
Aug 15, 2015 08:24 AM
bryan623
Aug 10, 2015 11:33 AM
