Third Gen Association of Ontario Regional message board for everyone in Southern Ontario and nearby regions.
Lower control arm bushings
Old Jul 27, 2003 | 04:56 PM
Idlehands's Avatar
Car: 1985 Trans Am
Transmission: 5 Speed
ok replaced my lower control arm bushings, and now the car's front end is sitting to high, so i loosen the bolts up put a jack under it and jacked it up , tighten the bolts, damn things is still too high.....any ideas..?
Old Jul 29, 2003 | 10:05 AM
screamin'chickn's Avatar
Car: 86 T/A
Engine: 327
check to be absolutely certain the bottom of the spring is properly seated in the control arm. There is a little pocket for the end of the spring, if it is not aligned when you put it back in, it will hold the spring up considerably. New bushings definitely won't change ride height.
K
Old Jul 29, 2003 | 09:01 PM
Idlehands's Avatar
Car: 1985 Trans Am
springs are seated properly......and everything seems fine
Old Jul 29, 2003 | 09:46 PM
ROCHEAD's Avatar
old bushings may cause sag in the front so trhe new bushings might bring it up to specs not normally seen on third gens? i put new springs in when i did my bushings cause i found that both my spring were broke on the bottom ring hehehe. makes sense doesn't it?
1992rs/ss
Jan 31, 2025 05:10 PM
deracer
Apr 11, 2016 12:04 AM
1992rs/ss
16
Jan 28, 2016 09:58 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
