Third Gen Association of Ontario Regional message board for everyone in Southern Ontario and nearby regions.
hatch problem?
Old Aug 9, 2003 | 09:49 AM
easySPEEDcamaro's Avatar
Car: 1992 Camaro Z28 Anniversary Edition
Transmission: Borg Warner 5-Speed
hatch problem?
it was really hot the other day so i wanted to take my roof off, i hit the hatch button, and hatch wouldn't come up
then later i'm just driving and it pops open, so i jump out and shut it...
was it just the heat?
i heard the motor going very slow, and it took about 30 seconds for it to actually initialize to go up, it just saw down wihle it was open...
suggestions?
Old Aug 9, 2003 | 11:42 AM
RegaPlanet's Avatar
Car: 1991 Camaro RS
Engine: 406
Axle/Gears: 3.42s
Sounds like gremlins to me... is your hatch button sticky at all or do you have a remote hatch switch?
Old Aug 9, 2003 | 07:15 PM
SBlackfoot's Avatar
Car: '90 Trans Am GTA
Engine: LB9
Axle/Gears: 2.73's
Tired struts?
Old Aug 9, 2003 | 10:16 PM
yeah and another thing... my passenger side power window keeps just stop working all the time... the ****ing buttons in the middle won't control it half the time and it works only when it wants... any ideas on that? i had the passenger side window rolled down today and i couldn't get it up, had to wait and then it started working...
Old Aug 10, 2003 | 12:54 AM
Azure's Avatar
From: "No one cares if you're in before the lock!" - Best quote ever.
For the hatch, just convert it to manual - the power release will still work fine, and as long as you have good struts, the hatch will still raise magically...it's what I had to do when my motor f*cked up on me. It's really simple...just ind the point at which the hatch motor/lock pulls own to, and score it/mark it somehow...then detatch the motor from the lock mechanism, and drill/screw/weld whatever the lock at the low point of the pulldown (test the distance beforehand, of course). The hatch will need to be pushed down to close now, but the power unlock will still work, and should still spring up and open (mine does, anyways). I hated waiting for that damn motor to begin with...it has about as much power as the 2.8 under the hood! :P
Old Aug 10, 2003 | 02:40 AM
RegaPlanet's Avatar
Car: 1991 Camaro RS
Engine: 406
Axle/Gears: 3.42s
If you're having problems with your hatch not even beginning to release as you push the button and your pass window not working all the time I'm really thinking its a connection in your centre console. However your hatch may also just be on its way out too from how you describe...
Old Aug 10, 2003 | 04:29 AM
88305tbi's Avatar
Car: 88sc
Engine: 305 for now
Axle/Gears: peg
Re: hatch problem?
easy's flipped his lid...
:sillylol: :sillylol: :lala:
serioulsly dude, i'll vote with rega and say electrical. best case, loose contact. worst case, motors going south... i had a problem with my lighter - plug in my phone or the lighter and a big spark show would result... swapped the barrel out for a new one, made sure all connections were fine, and works like a charm.
Old Aug 10, 2003 | 08:16 AM
Daz's Avatar
Daz
Car: 87 Camaro
Engine: Chevy V8
Transmission: auto
remember the electrical drain youre having?I bet its still a grounding or short problem.The hatch release shouldnt function when the car is running(on drive).The hatch works with a ground wired switch..
Daz
Old Aug 10, 2003 | 07:38 PM
SBlackfoot's Avatar
Engine: LB9
Axle/Gears: 2.73's
An electrical problem really doesn't explain why the hatch only opened long after he hit the button. If it was a wiring problem then it would open whenever it wants. Even then, something would have to be really screwed up in this mint car for it to electrically release while in gear.
I'd still lean towards the struts. The latch may have released but weak struts may not pop the hatch up right away. Then he takes off, and when he hits a certain bump, up it goes. My struts are on the weak side. When I hit the button it unlatches, but usually doesn't come flying up (sometimes it does, the light spoiler makes that scary). If I forget I unlatched it, it could come flying up (and it has, nearly hitting the garage door overhead) at any point.
As for the window, the first thing I'd do is pop the switch when it's acting up and short it out to see if the rest of the system is okay. It could just be a dirty switch.
Old Aug 10, 2003 | 07:45 PM
88305tbi's Avatar
Car: 88sc
Engine: 305 for now
Axle/Gears: peg
well, my struts are kinda shot... depends on the temp out whether it'll stay up or not, and it definitely doesn't go flying up, but if i leave the hatch for too long without pulling it up, the latch will suck it back down again. was kinda frustrating before i had the remote wired to pop it from outside...
Old Aug 11, 2003 | 02:35 AM
RegaPlanet's Avatar
Car: 1991 Camaro RS
Engine: 406
Axle/Gears: 3.42s
...but if i leave the hatch for too long without pulling it up, the latch will suck it back down again.
Haha, that's my favorite part about our cars. I love telling my buddies to come check out my motorized hatch and then watching it come up and go right back down immediately half the time due to worn struts.
Old Aug 11, 2003 | 05:21 AM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
Engine: 5.7L EFI LTR setup
Transmission: T-5 World Class
Hay man ...... if you got an electrical problem ....... fix that chit fast man ...... I had a faulyt switch on my 88 Grandprix .......and the relay cooked ....... a nice smell of burning plastic . But I could never lock my doors ...... dam relay kept popping them open
good luck man
Street Lethal
Apr 30, 2019 12:14 PM
hydrolic144
Sep 8, 2015 06:55 PM
2012sergen11
Interior Parts Wanted
Sep 7, 2015 11:37 AM
neekolzun
Aug 24, 2015 04:59 PM
madsv1000
Aug 20, 2015 06:45 AM
