Third Gen Association of Ontario Regional message board for everyone in Southern Ontario and nearby regions.
Fast Idle?
Old Aug 14, 2003 | 07:00 AM
IROCKER's Avatar
Fast Idle?
This is the second time my car has done this in the past couple weeks...I start it up and it idles at 1500-1750 RPM. The first time it happened I just shut off the car, waited a minute and started it up again and then it was fine. But last night it would not drop...the engine was already warmed up, I tried shutting off the car and restarting, I tried blipping the throttle a couple times and no success.
What would cause a TPI to run at high idle like that?
Old Aug 14, 2003 | 08:48 AM
RegaPlanet's Avatar
Car: 1991 Camaro RS
Engine: 406
Axle/Gears: 3.42s
IAC??? I've read on other posts here of the needle getting sticky and just lubing it a little fixes the problem. I'm not sure if this is only with TBI setups or if it's the same for TPI but through I'd throw out a guess.
Old Aug 14, 2003 | 09:18 AM
Cruzin Kaz's Avatar
Car: 85 Monte Carlo SS...
Engine: T.P.I L98.
Transmission: TH350
Axle/Gears: 3:73 Posi
I replied on SOGM to Chris.
Old Aug 14, 2003 | 11:56 AM
IROCKER's Avatar
Thanks guys, I'll take a look at the IAC toinight. It's a relatively new part so hopefully it's only just dirty.
Old Aug 14, 2003 | 02:08 PM
RegaPlanet's Avatar
Car: 1991 Camaro RS
Engine: 406
Axle/Gears: 3.42s
relatively new eh... hmm... well if it's not that doesn't the coolest temperature probe also control idle speed? just thinking ahead...
Old Aug 14, 2003 | 02:16 PM
Cruzin Kaz's Avatar
Engine: T.P.I L98.
Transmission: TH350
Good point Justin! Yes the CTS can cause idle problems , but more so as a rich/lean situation though for the most part.
Old Aug 15, 2003 | 12:10 PM
trigger GTA's Avatar
Car: 92 TA vert
it can also be your TPS
you can run a scan and read all the sensers,
Old Aug 15, 2003 | 04:34 PM
IROCKER's Avatar
Well I ran the scan after cleaning the TB and IAC. I haven't had a chance to read the logs yet on my laptop cause it didn't have enough juice...and of course I couldn't recharge it.
I'll probably try to look at it on Sunday, but so far it was running okay. All the readings appear to be normal so far, but I'll have to compare them to some old logs to be sure any other varibles aren't off.
Bubbajones_ya
Jul 6, 2024 08:32 PM
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
db057
Apr 28, 2019 07:45 AM
IROCtometal
Sep 20, 2015 11:08 PM
IROCtometal
Sep 9, 2015 10:01 AM
