Third Gen Association of Ontario Regional message board for everyone in Southern Ontario and nearby regions.
Damnit
Old Aug 25, 2003 | 10:10 AM
theREIS's Avatar
Damnit
Engine turns but no start. I am thinkin its my fuel pump cause I cant hear it anymore. What could be wrong??????
Old Aug 25, 2003 | 11:01 AM
Steve89GTA's Avatar
How about fuel pump relay? Apply 12v to the fuel pump test terminal (G if I'm not mistaken) on the aldl diagnostic port. If you hear the fuel pump, it's probably the relay.
Old Aug 25, 2003 | 11:07 AM
Cruzin Kaz's Avatar
Car: 85 Monte Carlo SS...
Engine: T.P.I L98.
Transmission: TH350
Axle/Gears: 3:73 Posi
You also may have blown the fuel pump fuse under the hood. IS your car a Camaro or a Firebird. Camaros have this fuse on the passenger side near the battery, most firebirds have it on the driverside on the side of the rad support. Looks like this..
Old Aug 25, 2003 | 04:23 PM
tanager11's Avatar
Car: 91 Z28 Vert
Transmission: TKO
Axle/Gears: 3.55 10-bolt
That is what that fuse is for....I always wondered!!!!
Old Aug 26, 2003 | 10:30 PM
freestylzz's Avatar
Car: 1987 Iroc Z28
Engine: The KING of the 3rd gen TPI's.
Transmission: Beefed up T5
Axle/Gears: Aussie 3.45's
Check the ignition coil relay under the distributor cap. I had the same problem and had to replace it. Cost me like $60 or so ( that was 5 years ago ). I had exactly the same problem in my '93 Merc Topaz ( daily sh*t kicker ) last month. It was the electronic ignition coil module ( cost me freakin $130). Anyways hope maybe this helps.
sogabe
Jun 16, 2006 01:09 AM
ScrapMaker
Car Audio
53
Oct 22, 2005 11:57 AM
acescarrsRS
Pacific Region
16
May 27, 2004 03:25 PM
ChrisFormula355
South West Region
May 6, 2004 02:43 PM
RS'er
Feb 19, 2002 11:14 PM
