Third Gen Association of Ontario Regional message board for everyone in Southern Ontario and nearby regions.
what tool do i get and how?
Old Sep 18, 2003 | 03:01 PM
icebird_1981's Avatar
i have a bolt that is striped and i really need it off. what tool do i need to get to get it off. this is the bolt holding the hatch glass so i need to do this with care. can someone please tell me how and what tool i need to get. i made a pic below..
in a older post someone said drill it out, how would i do that?
Old Sep 19, 2003 | 05:49 AM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
Engine: 5.7L EFI LTR setup
Transmission: T-5 World Class
grab a drill bit .... that is close to the size of the bolt .... and drill 'r out
sounds like your only option ........ but I would approach a body shop just to see if they have had any experience with doing this ...... there might be a tool
Old Sep 19, 2003 | 07:13 AM
bubbareno's Avatar
Car: black on red 92 rs
Transmission: t-5
What about an easy out bit? Dope sory my bag he said bolt drill.
Old Sep 19, 2003 | 08:28 AM
6speedIROC's Avatar
Car: 86 IROC
Engine: LQ4 6.0L
Axle/Gears: 3.55 8.8
Why don't you grind the bastard clean off?
Old Sep 19, 2003 | 09:12 AM
Briansz28's Avatar
Grind thru the nut with a Dremel and cutoff wheel. Or, I have used a nut splitter( Sears has them) with mixed results. Usually I use the splitter, mangle the nut and then use the Dremel to finish. Worst was a lug nut
Old Sep 19, 2003 | 10:02 AM
George's Avatar
Car: 83WS6TA
Engine: ZZ4
Transmission: TH350C
Axle/Gears: 3:23
Something to be aware of -- I read somewhere that if you overtighten the bolts holding the rear glass the window will shatter as in explode. So you might want to follow up on this issue.
Old Sep 19, 2003 | 10:09 AM
thanks, i am gunna go check out some body shops and see what they say, proplem is i just cant bring the hatch and ask them to do it for me, its to big. nothing is ever easy is it.lol
92projectcamaro
Dec 8, 2015 12:25 AM
tyeo098
Nov 30, 2015 06:27 PM
Reid Fleming
Oct 10, 2015 09:56 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
mrdevontay
Sep 2, 2015 08:04 PM
