Third Gen Association of Ontario Regional message board for everyone in Southern Ontario and nearby regions.
2.8 v6 to v8
Old Feb 28, 2005 | 09:03 PM
BigBen54's Avatar
Car: 87 Camaro
Engine: booo=2.8 V6
Transmission: auto
2.8 v6 to v8
Hey im new with cars so im just woundering how hard is it to switch over a v6 to v8 and what would i need to do. I couldnt do it my self so i would probly half to get someone to do it for me. Also how much would it cost to do somethin like that?
If i can switch the engines around how big could i go?
The car I want to do this with is a stock 1987 camaro.
thanx
Ben
Old Feb 28, 2005 | 09:44 PM
HalfInchWrench's Avatar
Car: 85Z28 87GTA 91GTA 98SS
Engine: SBC, LS-x
Transmission: T-5, 700-R4, T-56
It depends on how much work you can do on it yourself. If you are not mechanically inclined then it will cost a lot. Like I said to you privately, it's cheaper to buy another car. This may be too much for you to start out wrenching on. Try some smaller stuff first like fixing problems. Don't worry, I was no different when I was younger. I bit off more than I could chew, thought I could do anything when I was 18. I couldn't but I didn't let that stop me. A little help and guidance can go a long way.
Where about's do you live? Might be someone from this fourm near by to help you out.
I am about to do an engine change/tranny change in a 3rd gen. If you want, drop by and watch or even help out. I've started more than a few people wrenching already. Once you get past that initial fear and a few techniques under your belt, there is no stopping you. I've seen more than a few guys not know the difference between left is lose, right is tight to doing anything. I'm in Ajax.
A big block fits so you can go as big as you want. Most folks stick with a small block which is limited to around 420 cubes.
Old Mar 1, 2005 | 05:36 AM
Daz's Avatar
Daz
Car: 87 Camaro
Engine: Chevy V8
Transmission: auto
Its actually easier to change plugs with a big block..Everything from the top in 15 minutes taking your time
I agree with 1/2". THe only way it would be worth it is if the body of your car is mint and you have all the options that you efer wanted in a car. THe other reason is if you are planning on putting a motor with twice as much power as stock anyway. A parts car would still be more practical though for the odd parts.
Old Mar 1, 2005 | 02:41 PM
George's Avatar
Car: 83WS6TA
Engine: ZZ4
Transmission: TH350C
Axle/Gears: 3:23
Generally not worth it - lots of good V8 cars around.
Old Mar 1, 2005 | 03:42 PM
The_Wraith's Avatar
Car: 1984 Trans Am 15th anniversary
Engine: L69
Transmission: 700r
Axle/Gears: 3:73
not worth it at all.
Old Mar 2, 2005 | 01:09 PM
Kevin Vandevenne's Avatar
Car: 87 IROC
I agree with the rest. I've swapped out a 2.8 MPFI V6 with a carbed 305, and it is a fair bit of work. For someone who is starting out in the hobby, it would be better to start out with a V8. If you do decide to swap in a V8, I suggest buying a running V8 parts car and getting the parts you need off of it. It will save a lot of hassle in the long run, rather than trying to hunt down parts in a junkyard.
86maro_252
Oct 10, 2015 06:52 PM
usafirebird
Sep 29, 2015 11:58 PM
spartanreaper
Sep 25, 2015 07:22 PM
RABMAN
Interior Parts Wanted
Sep 18, 2015 09:02 PM
89bird2.8
Sep 18, 2015 07:46 PM
