Good Engine Builders In The GTA
Car: 1987 IROC in need of MAF
Engine: 350TPI
Hi ....I'm looking for some good engine builders in the GTA(I'm located in Mississauga), I have a 87 IROC 350 TPI that has been stored for the last 18 yrs (PROPERLY) with 10K original kms. ,I am the original owner and I am thinking of swaping the motor out and store it and replace it with a 383 TPI or carb setup with 400+ HP & TORQUE .Anyways if you have any recommendations for a engine builder please forward names,I also am investigating a crate ZZ383 from GM any thoughts on this option would also be appreciated.I am looking for some more power but do not want to rip apart the stock original motor,just in case......
Rob
Rob
Car: 83WS6TA
Engine: ZZ4
Transmission: TH350C
Axle/Gears: 3:23
Here's two for reference. I have not had any motor work done at either of them.
Agostino Racing Engines:
They are a big shop at 427/401 area. Mainly LS1 and stuff like that. Had some bad customer relation problems in the past but are supposed to be working at turning that around. Likely expensive and I don't think I'd take my car there as they're probably not really focused on third gens and as I've said they have some past issues.
Straight Line Racing:
Small shop in the Kennedy/401 area. They seem to have good prices on parts. I got a Demon carb from them last month and it was well under the other quotes that I had - according to Agostino, my price was better than their cost for that carb. There's a guy on here has had some serious motor work done there and I think he was happy with it last time I heard anyway. I'd consider using Straight Line.
Crate Motor:
I thought I could eliminate the vagueries of dealing with engine builders by getting a crate motor. I had a problem with mine but it should be OK and if it's not there's still a one year warranty. I'd probably go that route again even though people are correct when they say you can build something with more power for less money. However, I don't drag race so 350 or so at the FW is enough and the crate motor seemed the easiest solution.
Another thing is that I managed to get the motor for cost from a dealer in a small town. I have all these supposed dealer discounts through car clubs in Toronto but none of them could match the price that I got just by calling around.
Carb v. FI
There's a post about winter mods on here from a few months ago which covered the main points.
Good luck with car and post some pictures.
Crate Motor:
Carb v. FI
Car: 87 Camaro
Engine: Chevy V8
Transmission: auto
I dont have any engine builder recommendations (all are far from herebut I would suggest on keeping it TPI.
It seems like you are going to swap the original 350TPI back to the car.Its not hard to pull the harness out and separating the HVAC wiring but you will have to join the two together which is a pain IMO.
Also if youre going for a crate motor and a TPI then try to change the cam that will suit the TPI.
George,
You have a contact name for Straight Line? I always wanted a Demon
George,
Car: 83WS6TA
Engine: ZZ4
Axle/Gears: 3:23
Originally posted by Daz
George,
George,
Engine: 350TPI
TPI-w-383 ????
Is it possible to run an 383 with 400+HP and utilize the TPI with not TOO much tuning ? I just want something that I can bolt up and not re-invent the car.Also I'm pretty handy when it comes to mechanics ,did some pricing on the GM ZZ383 and some custom builds from a couple places and they seem a bit HIGH !!! Where would I get the specs. and necessary part numbers and manufacturers for all the necessary components to build my own 383 STROKER with 400+HP and 400+ TORQUE with the reliabilty of a daily/play driver ? Any suggestions would be greatly APPREICATED.
Thnaks
Rob
Thnaks
Rob
Car: 1985 IROC-Z / Z-28
Engine: 383 C.I. Stroked 6.3 Litre
Transmission: 700R-4
Axle/Gears: 3:73 Posi
Talk to Andy at Straight-Line Racing 416 757-9804 he is a real stand up guy with an excellent reputation and one of the best in Ontario for building motors
Like George said: "Some on here has had some serious motor work done there"...well... that guy is me
and I am really happy with the results
My set up: 383 Stroker, Edelbrock Performer RPM Heads 2.02 (Ported & Polished), Edelbrock Victor JR. Intake, Edelbrock Aluminum Waterpump, Demon 750 Double Pumper, Comp Roller Cam (XR294HR...248 dur. @50/ 560 lift.) Roller Rockers, Edelbrock Gear Drive, MSD Distributor with 6-AL Box, SLP 1 3/4 Headers (Ceramic Coated), Griffen Aluminum Radiator, Billet Overflow Tanks, Billet Wire-Looms, Edelbrock 3 Point Strut Tower Brace.
Let me put it to you this way a couple of years back I went to Kitchener/Waterloo area for a dyno test with a bunch of other guys and oane of them had the 383 T.P.I. when we pulled on the dyno the T.P.I. got 271rwhp/400rwt and mine got 350rwhp/380rwt and that's without the ported heads and 1/58' headers and a 650 Demon carb
Car: 1995 Formula/2001 GTP
Engine: 5.7 LT1/3.8 Supercharged
I wouldnt bother with Agostino. Unless youre some high roller from the US dont waste your time. Nick himself, is actually a ***** if you ask me. But apparently he had a heart attack and doesnt run the shop anymore. I dunno, i dont pay much attention to them, but I know a couple people who dealt with Nick and were very disappointed
In Streetsville (Mississauga) is a shop named Mississauga Engines. Its owned by a guy named Cesear. Nicest, most honest man in the world. Of all the work done on my cars by anyone, I was most impressed by him. He goes out of his way to help you and to help your situation. and hes really good at what he does. I would recommend him to anyone.
As far as straightline goes, I work down the road and stopped in a few times and they seem like good guys. Heard some good stuff. No personal experience
Engine: 350TPI
Greatly Appreciated
Thanks for all the direction/recommendations,I am going to see Andy at Straight Line on Friday,I'll give Ceasar a call in the morning since his shop sounds like about 10mins. from my home.
Thanks Again Guys,I truly appreciate it,I have been out the game for awhile like 18 yrs. mainly due to other commitments.....FAMILY ,work,FAMILY,work,FAMILY,work I think you've got the picture.....and this IROC ,I just couldn't get rid of it,GLAD I didn't.It actually has the original windshield washer in it from 1987,over half of it is evaporated, this car actually believe or not has only seem rain 3 times,never been in snow,it has seen it through the garage windows.Anyways if anyone has some personal recommendations on how to get 400+HP and lots of TORQUE I'm all ears and willing to experiment.
Rob
Rob
Car: 83WS6TA
Engine: ZZ4
Axle/Gears: 3:23
Re: Greatly Appreciated
Rob
Rob
The Crap Tyre store at 427/Queensway has a cruise night every Sat from about May to Oct. The local f-body clubs usually meet there a couple of times over the summer - might want to check it out.
Another thing too is that your car is probably worth a fair bit of coin as it is - every now and again they come up on Barret Jackson or whatever with like 2-3K miles on them and sell for 18 US or so.
Engine: 350TPI
WOW.....
Maybe I'll store it for another 18 yrs. and get $40+ US for it......you know what ,I'm just gonna do that......thanks for the tip...
Rob
Rob
If you're already in Mississauga- you may want to try Beatty and Woods- they are right next to the airport. Chuck and Jeff are the owners, telephone is 905-405-8500.
I would call a few places to see what they recommend and what they're going to charge before deciding definetively on any one shop.
Car: 87 Camaro
Engine: Chevy V8
Transmission: auto
lol another person that knows Ceasar...MAybe you can tell Ceasar to change his cam program to a newer one that and stop having sex with his Yamaha motored Ford....lol
He's an OK guy but try your best on bringing somebody who knows him ..
Car: 82 Z28 T-Top
Engine: 010 Nickle Block/ Spare LS1
Augustino Racing I find they are good if you have US dollars... but I dont have the cash for their work. They are popular with the americans. Especially LS1 stuff. Another reason why they moved is cause **** kept going missing... I mean like you give your leave your car with them for a couple days and all of a sudden it gets broken into and your t56 gets stolen, lots of **** goes missing from that shop. But thats when they were in Ajax, their new shop is very close to my house now, dont know how their doing in the new place, but so far so good they got rid of a lot of their problems.
Andy from Straight Line Racing is great you cant get a better cash deal on your projects for sure.
But my 2 cents is for Mississauga engines.... Ceaser knows his stuff... he really knows what parts match eachother.
Car: 83WS6TA
Engine: ZZ4
Axle/Gears: 3:23
Agostino is in pickering and has been there for atleast 4 years that i know of.
Car: Camaro
Engine: 6.2L
A Mopar friend of mine had engine work done at straight line. Hes running mid 11's and very pleased. Price was good and I have met the guy there a few times and he seems pretty straight up... ( okay bad joke
I have not personally had any experience with Mississauga Engines but through very respectable sources I have heard only good things.
Car: 85Z28 87GTA 91GTA 98SS
Engine: SBC, LS-x
Transmission: T-5, 700-R4, T-56
ARE is now called Autoworkx or something like that. Moved from Pickering as mentioned.
Many folks have had serious problems. Read this long but informative thread: http://www.ls1tech.com/forums//showt...0&referrerid=0
Car: 83WS6TA
Engine: ZZ4
Axle/Gears: 3:23
Nice to see that their repuatation is following them. I'd read some stuff on LS2 about them but I didn't know they were that bad.
Also, companies can't avoid their legal obligations by moving across town and starting up with a new name particularly if it's substantially the same operation. A court would likely order that claims against the old company would still be valid against the new company
Ya i didnt know they moved. Last i heard Nick had a heart attack so Wade took over the shop. Wade wasnt a bad guy and I know a long time ago he used to do their really good machine work. But i guess with all the success and all the work they had, they got some scabs or something to do it. Either way. They did the machine work on my brother's 383 LT1 Vette and he wasnt impressed with the work, or the ethic.
Wow! That's alot of people apparently screwed by ARE. I didn't get the best 'vibe' off the place when I had a tour back in 2002 (2001 maybe?)- seemed a bit 'money hungry'. In any event I think trying to deal with their new corporate existence would be quite risky until they get their old customers all sorted out and satisfied. All this talk the ARE defenders make of "there will always be dissatisfied customers" doesn't even come close to explaining the huge level of irritation and anger by apparently so many people- I've known small businesses that have been around for 20+ years and can count the number of serious complaints they've had on one hand.
Engine: SBC, LS-x
Small bus. fail/rip off people all the time and open up under a new name with no implications. Just look at what happens in the home renovation bus. Lots of scammers taking people for 200K and getting away with it. Then they open up another shop and it repeats over and over. I don't know what I would really do if someone took me for that much coin but the thought of cutting them up and hiding them would certainly be on my mind.
Car: 83WS6TA
Engine: ZZ4
Axle/Gears: 3:23
Engine: SBC, LS-x
Originally posted by George
Certain transactions are reviewable particularly if they were done to defeat creditors - however, I'm not going to argue about it - believe what ever you want.
Car: 83WS6TA
Engine: ZZ4
Axle/Gears: 3:23
What happy ending stories do you know about that has been wringed thru the courts for a company who claims to have "gone under"?
Engine: SBC, LS-x
That sounds ok but it's just one case.. I assume you are a lawyer. A good fiiend of mine is too and deals with this some of this stuff all the time. He has won some big cases against some big companies and the Toronto Police that you will never hear about in the media. He doesn't like the way small cases are worked out. You are right about most being settled out of court. The vast majority are not even persued that way cause it's simply not worth it.
Car: 87 Camaro
Engine: Chevy V8
Transmission: auto
either way..
Ceasar is of Mississauga engine is a good guy and knows a lot.He is a little old school though.Well I am too but he's older school ..
Car: 87 Camaro
Engine: Chevy V8
Transmission: auto
Originally posted by 87roc_t56
Hey man being into third gens I think we are all old school now
Car: Camaro
Engine: 6.2L
Talk about Hijack! Yeah man no problem if you want to swap bring em up and I'll get her done for you. I asked my buddy about drilling the brackets and he never got back to me so? I will ask again and see what he says. If not i have other sources that may be willing to do it.
Car: 87 Camaro
Engine: Chevy V8
Transmission: auto
thats ok man,I actually figured out how to do the spindles..I figure if I mess up I can always just use a nut and bolt. Ill see if I can stop by there on SUnday.
Question for you about the C5 swap though
I got the C5,hubs,LS1 calipers and LS1 carrier.You think I can use the LS1 carrier with the C5 rotor(13")?I assume the LS1 pads are the same as the Z06 pads too right?. I was told that I cant use the LS1 carrier if Im using the 13" rotors and C5 brackets..so I guess Ill just get the C5 carriers then. Last thing.Do you have spare C5 carriers hanging around?
Car: Camaro
Engine: 6.2L
No I dont think you can use the LS1 carrier ( caliper bracket ) with the C5 rotors. No again sadly i dont have any extra C5 brake parts lying around. I only bought what i needed last year. I am curious though... Nut and bolt??? Exactly how can you use a nut and bolt unless you plan on drilling right through the strut collar throat of the spindle which sounds scary dangerous to me. I'm not trying to dig at you man just a little concerned is all. The lower bolt hole on the spindle ear you could drill through and use a bolt but not the top one.
Car: 87 Camaro
Engine: Chevy V8
Transmission: auto
Engine: SBC, LS-x
Talk about a hijack! No C5 caliper bolts don't work on a 3rd or 4th gen cause I've done a retrofit using them. Had to cut off the bolt bosses and fit a bracket on to the back side. That was on a 4th gen. 3rd gens woud have to be very different cause of the way C5 brakes work. Nothing in common.
Car: 87 Camaro
Engine: Chevy V8
Transmission: auto
Car: 87 Camaro
Engine: Chevy V8
Transmission: auto
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
Good Idea to store your stock TPI motor and build another one.
A 383 is a good way to go.
The stock TPI intake manifold is all about low mid range torque. Power-wise it tops out about 350-375 horsepower
reguardless of what else you do to the motor.
The manifold runners are just too long and too small to make higher horsepower.
You need to shorten the manifold runners to gain high rpm flow and pulsing.
This is why manifolds like the Super Ram, Mini Ram stealth ram, RamJet and LT-1 intake work better at that power level.
All these have shorter runners.
For a budget build A modified LT-1 intake swap is hard to beat.
You can use much of your existing wireing and fuel system with a few upgrades and mods.
Modified LT-1 intake manifold
Once you let that sink in and ditch the idea of trying to get 400HP from a stock TPI intake and runners, the rest is pretty basic.
I know the TPI is pretty looking and you have one but it's just a bottle neck when it comes to making more than 350-375 HP even with aftermarket runners.
If you don't mind a little drive down to the Niagara area,
I can recommend a shop where you performance dollar will go a little further. I get my work done there.
Hot Rods Inc.
Ask Daz, he knows them.
Hot Rods Inc.
Engine: SBC, LS-x
Originally posted by chevyrumble83
strate line raceing, there the best>416-757-9804
Don't make me post pic's of your little twinky that your wife has plastered all over the web. Wouldn't be fair to you with your floppy.
Car: 87 Camaro
Engine: Chevy V8
Transmission: auto
Hot Rods Inc.
Hot Rods Inc.
Car: 1987 Iroc Z28
Engine: The KING of the 3rd gen TPI's.
Transmission: Beefed up T5
Axle/Gears: Aussie 3.45's
I'd have to recommend Andy (owner) at Straightline Racing on Munham Gate in Scarborough (Toronto).
He may seem a little "cold" when you first get to know him but I think that's cuz he's so busy and has no time for people wasting his time. So be forward and know what you're looking for and want.
He's been there almost 20 years now (I believe). I've had work done there in the past and he's fairly reasonable on his prices. He's a good hook up for aftermarket performance parts aswell. I know quite a few people who've had work work done there also.
He's a pretty standup guy when it comes to backing up his workmanship. Expect to "book" at appointment with him 1 1/2 to 2 weeks in advance to have work done. He's pretty busy around this time of the year. Everytime I go in he's alway got some nice vette, firebird, camaro, GN, or other old and new muscle hovering around. I'm pretty sure "the power's that be" are cracking down on him aswell since it is a speed shop so I don't know how things are lately.
Also nice to know he's a chevy guy (at heart)
The_Phoenix
Feb 4, 2016 07:10 AM
NinjaNife
Aug 23, 2015 11:49 AM
