Third Gen Association of Ontario Regional message board for everyone in Southern Ontario and nearby regions.
update on my project car
Old Dec 16, 2005 | 07:08 PM
trigger GTA's Avatar
Car: 92 TA vert
It’s been a wile from the last update but I have managed to get a lot of stuff done.
First off.
The floor is now back in and totally welded. Just needs some primer to cover the welds ups. The old one was spot welled all over. I took it one step past that and also welded the seams too. I am not going to install the seat mounts or center armrest until I decide what seats will be going in
There were some holes in the strut tower mount. That also needed to be repaired so I took the time to fix that and add in a thicker plate so I will be able to run coil over suspension and not have to worry about it failing under load
that now bring me to where I am now. starting to relocate the gas filler neck and shave off the gas door. the new gas cap is going to be located behind the left tail light. The taillight will swing out of the way for filling
First thing was to cup the hole
Next was a paper template of a box so that the neck and gas cap can be sealed from the cabin of the car. (Stopping gas smells and water from getting in)
Next was to cut the metal and bend it up
Some test fitting and trimming then it’s was ready to weld up
Next part will be to get a new tube made to mate up with the old one from the tank.
Old Dec 16, 2005 | 07:44 PM
George's Avatar
Car: 83WS6TA
Engine: ZZ4
Transmission: TH350C
Axle/Gears: 3:23
Speaking of failing under load - are you going to use a tubular cross member.
Nice work by the way (although I've seen better welds..lol) I wish we had something like the Kitchener Highwaymen Club around here - be nice to have a shop like that. The one I was in didn't work out because it was too far to drive there.
Old Dec 16, 2005 | 08:20 PM
Car: 92 TA vert
what you dont like my welds lol ya they suck. the ones that i was on my back even more so. thats why i got a realy nice grinder
i was thinking about a tubular kmember to make room for the turbos
Old Dec 16, 2005 | 09:01 PM
George's Avatar
Car: 83WS6TA
Engine: ZZ4
Axle/Gears: 3:23
From what I've read a lot of road racers have concerns about them being too fragile. I think there's some posts of frrax.com about it. May not be an issue but obviously something to look into.
Old Dec 17, 2005 | 02:36 AM
Daz's Avatar
Daz
Car: 87 Camaro
Engine: Chevy V8
Transmission: auto
I gave up the tubular setup(control arms,crossmember and coliovers)because of my heavier engine in the front.
Old Dec 17, 2005 | 07:09 PM
Ratchet's Avatar
Nice work Trigger. I thought the welds looked great. Nice touch with the relocated filler neck. I can hardly wait to see all the other cool mods you are going to lay on that thing.
Ric
angel2794
Theoretical and Street Racing
25
Mar 7, 2026 01:08 PM
Frozer!!!
Jan 19, 2024 04:55 PM
Fast355
Dec 2, 2016 06:33 PM
TreDeClaw
Aug 14, 2015 06:58 PM
bryan623
Aug 10, 2015 11:33 AM
