Injectors
Car: 87 GTA t-top
Engine: L98 350 w/RMT
Axle/Gears: 9 bolt BW 3.45
Injectors
This may seem like a dumb question but to those who know:
Would getting 33lbs injectors help my chances increasing HP/ Torque on my current stock setup?
If not is there anyway gaining more power with 33lbs injectors, new chip, intake?
Car: 87 Camaro
Engine: Chevy V8
Transmission: auto
Re: Injectors
Car: 92Z28, 99SS, 83Z28 & 86GTA
Engine: 421, LS1, 327Turbo & 383
Transmission: T-56, 4L60E, T5 & 4L60
Axle/Gears: 4:10, 3:42, 2:73 & 3:27
33#
You'll loose power man, wont atomize worth didly when you adjust the duty cycle enuff not to flood the car
Only way they'll work is to basicaly change the whole enigine around to one that needs that much fuel, AKA heads, cam, bigger displacment, ect ect ...
You'll loose power man, wont atomize worth didly when you adjust the duty cycle enuff not to flood the carOnly way they'll work is to basicaly change the whole enigine around to one that needs that much fuel, AKA heads, cam, bigger displacment, ect ect ...
Car: 87 GTA t-top
In other words, change a few main factors before dumping more fuel, thanks guys I wasnt 100% sure about that.
Thing is if the stock computer only tells it to dump so much fuel as a 22lbs wouldnt it just run the same until you programmed it to dump more?
Car: 1989 IROC-Z
Engine: 5.7L EFI LTR setup
Transmission: T-5 World Class
So it would be a mess. Could even wash the rings out and fry'm up .
I can sum it up, would work very very badly
I'll try to break it down as understandable as posible, try to use english instead of tech talk
If your computer is set for 22# Injectors running at 85% of there max for a decent life span. then you pull te 22# and stick in 33# without adjusting the computer. It will still be trying to dump 85% of 22#, but 85% of 33# will be alot more fuel, thus washing out the car. Your O2 sensor will try to compensate but ... ever seee an ant try to take out a beehive on its own??
Then there come's atomization, lets use a garden hose as an example, with no nose on it the water just kinda falls out of the end, eh
Put on a nose (smaller end) and it shoots out with nice volosity. now pretend thats gas and on fire, the droopy gas will burn but like crapola, but with the smaller end on it you got yourself a nice little flame thrower
Originally posted by Daz
and if you lower the constant(%) for a 33lb injector then it will just drip instead of spray..
if you stick a bigger injector without changing the constant it will not drip..It will still spray.
So I'll try this again
If he sticks them in without doing anything, its gunna flood the car with excessive fuel, if he turns them down to get the a/f ratio good then there gunna drip AKA no atomization
Easier to understand now, then what I had before?
Originally posted by Hawk92z-TDZ
33#
33#
You'll loose power man, wont atomize worth didly when you adjust the duty cycle enuff not to flood the carSupreme Member
Car: 87 Camaro
Engine: Chevy V8
Transmission: auto
Ok seem's my explainasion has confused even you, that means theres no way he'll get it, lol
question, have you actually tried changing the constant value of a chip? Or you just read about these things?
I have 412ci motor running under a TPI, u tell me
I know far from everything though, still learning quirks and asknig alot of questions to milk everything i can.
But I try to help when it gets to something I do know
Car: 87 Camaro
Engine: Chevy V8
Transmission: auto
I didnt ask about your motor that greeny is doing for you..
Not sure what your trying to insinuate but I never said I could assemble a motor myself, but I did design it myself, and John (Greeny) asks my advice on cam's and heads and such all the time, he's a personal friend that knows how to assemble a dam good motor
I have also designed quite a few friends street motors around my area all running 13's and 12's, and yes Greeny is the one that assembled them
Oh and John doesnt have chip burning equipment of any kind, he's a carb fan rmember
Now I remember why I normaly dont bother to help anyone on here
transamice your best bet to get advice would be to sign up on one of the following forums and ask in the tech section, helps get away from the idiots on here.
They seem to get off on childish highschool game's and intensionaly try to push your botton's for no apparent reason
http://www.ccfbg.com/forum/index.php...cfd86f62363c12
http://londonfbody.com/phpbb/index.php
http://www.kwfbody.com/phpBB2/index....fb4e853d7a6cc8
Car: 87 Camaro
Engine: Chevy V8
Transmission: auto
transamice,
watch for the experts here.Sometimes the advice that you get from here are not actual experiences just a passage that they read on some link.
Car: 87 GTA t-top
I appreciate the replies, its all good.
I wont be going that route anyways, I could probably go with larger injectors later on, maby 24lbs. Im not thinking of going too crazy, I just had an option to get 33lbs from someone and thought I would ask if it would help.
Asuming you got a 350 then 24# injectors would work fine
Another spot to ask is in thirdgen's actual TPI tech section
https://www.thirdgen.org/forums/tpi/
That is actualy true on here, but there is alot of peeps on the TPI tech that do know what there talknig about and do have some good experience
Originally Posted by Daz
transamice,
Car: 90 IROC 5.7 hardtop
Transmission: T5 swap
Axle/Gears: Yup -- they still work
Not an expert but I did do some injector upgrades and armed only with wishful thinking and good intentions found out the hard way (isn't that always the way?) to avoid stuff you don't know the intricate details about.
I installed 24s in an L98 they were mostly ok but the not ok stuff really started to bug me. In the end I had to
a) re tune the car (which I don't know much about) for the 24s
or
b) buy factory spec injectors
I opted for b) and also got a copy of tunercat and am reading everything I can from Moates and the DIY board.
If I was looking for extra power I wouldn't do it through injectors. Too many easier bolt ons available IMO.
RP
I guess some car's react diferently, we put ford SVO 24# injectors in Tim's 1990 350 Iroc and they worked perfectly fine with no tuning, only mod's at the time were a few bolt on's
Yah I found out later there are alot better pieces on the market like SVOs.
This time around I got Bosche 22lb'ers. Back to stock hey I just want something that drives well...
By the way glad to hear your car is going to be back on the road again.
Car: 1989 IROC-Z
Thing about haveing the 24 lb SVO 's is . They are rated differently than the GM stuff. They flow more than a 24 lb Gm injector ( just stuff I read ...don't really know) I would reallllly recomend getting the constant changed if running ANY 24 lb injector
thejimsterz28
Sep 15, 2015 04:37 PM
