Break System
Car: Camaro IROC Z-28 1987
Transmission: Automatic
Break System
Well I have a 1987 Camaro IROC Z28
I am extremelly happy with the car the last 5 years
But I don't know with you guys have the same problem that I have I feel the brakes of my IROC not enough for the kind of car that is.
I though in the begging the problem was the break system. so I replaced everything from booster and master cilindres to all 4 calimpers.... break lines and proportion valve....and still the same.....
It's normal the weak break system?
Tks
Tks
Car: 86 IROC
Engine: LQ4 6.0L
Axle/Gears: 3.55 8.8
Re: Break System
The rotors are only 10.5"..so not a ton or brakes on these cars unless you got the 1LE system.
You should have replaced your fronts with the C4 (corvette) HD conversion available from ebmiller. That would be a wicked setup.
What pads are you running?
I still run Performance Friction Carbon Metallics with much better results than OE type pads. Check the brake board and see what guys are running. I think Hawkes ibrand is a good pad..
Do a search on the brake board...pads are easy and cheap to change.
Car: 83WS6TA
Engine: ZZ4
Transmission: TH350C
Axle/Gears: 3:23
Re: Break System
There's a couple of corners where they fade away just as I'm done with them but for street use I'd say the stockers are adequate although C4 or C5 would be nice to have.
UltRoadWarrior9
Apr 28, 2020 10:39 PM
sailtexas186548
Feb 17, 2017 03:07 PM
