Third Gen Association of Ontario Regional message board for everyone in Southern Ontario and nearby regions.
buying camaro, need advice
Old Nov 25, 2007 | 06:21 PM
Faridk89's Avatar
getting an amazing deal, only a few problems with the car, its an 84 camaro:
1. passanger side window dosnt go down
2. small oil leak, the guy says where the dipstick goes into the motor, the rubber ***** off, is this common, or can it be somthing else
3. there is a leak in the firewall, and it leaks onto the floor, looks like im going to have to pop the dash out and fix it,
just wondering if these are common problems with the older 3rd gen camaro's and if it isnt to hard to fix these problems, thank you for reading!
Old Nov 25, 2007 | 08:26 PM
Alex IROC Z-28's Avatar
Car: Camaro IROC Z-28 1987
Transmission: Automatic
Re: buying camaro, need advice
Well brow....
I have a 87 IROC....
The window....can be many things....broken wire, the button bad, motor bad, the tracks that slide the glass are bad....but I don't think is a big deal.
The Leak can be many things like a gasket, etc....some of than easy to change others not that easy.....
Just for I understand oil inside the car floor? are u sure? Unless your oil gage it's not eletric use a hose to mesure de pression.....
I don't see anything important there......
Check for rust under the car specially under the plastic on the fenders.....
T-tops leaks (the rubber is not cheap!!!)
The basic of buying a car....
Old Nov 25, 2007 | 08:56 PM
Faridk89's Avatar
for the firewall, water gets through not oil, also its not a t-top and all the rubber has been replaced recently
do you think liquid metal could fix the leaks, thanks
Old Nov 25, 2007 | 09:26 PM
depending where leaks is better a nice weld is not a bed idea, if is by the glass is not uncomom....
Old Nov 26, 2007 | 10:30 AM
cam-'s Avatar
Car: Camaro
Engine: 6.2L
Wet floor usually means heater core leak
Old Nov 26, 2007 | 07:08 PM
George's Avatar
Car: 83WS6TA
Engine: ZZ4
Transmission: TH350C
Axle/Gears: 3:23
I was going to say heater core as well.
Took me a little over an hour to change the core and hoses on my TA. The dash didn't have to come out on mine anyway.
Core doesn't cost much from CT and the hoses are cheap too.
Wylecoyote08
Nov 6, 2015 03:46 PM
Derick15
Members Camaros
Aug 20, 2015 10:19 AM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
Newguy91rs
Aug 7, 2015 09:51 PM
