Third Gen Association of Ontario Regional message board for everyone in Southern Ontario and nearby regions.
89 L98 Hard Start issue
Old Jun 1, 2011 | 09:35 AM
Knight98's Avatar
Car: Trans Am
Engine: 350 L98
Hey all,
I have seached this board and others over and over all winter to find a solution. No luck. So I am wondering if anyone has an answer.
Problem: Hard Start issue when car sits in Garage. Need to crack 8 to 10 times to startup. Sometimes starts with no codes and idles perfect. Other times ruff idle and code. (EGR Code)
Done so far: Replaced
8 injectors
Fuel Pump
Plugs and wires
Cap rotor and igniton
MAF
IAC and TPS
EGR and gaskets for EGR and Runners
Replaced vacume hoses
New battery
Had timing set to factory specs
When the car does start with no code. Runs amazing. Lots of power no hesitation and idles great. If anyone has any ideas on what this issue is, please let me know. Been pulling my hair out for 2 years on this.
Old Jun 1, 2011 | 11:06 AM
hellz_wings's Avatar
Car: 1986 Chevrolet Camaro IROC-Z28
Engine: TPI 310ci (LB9)
Transmission: Custom Rebuilt 700R4 - 2600 Stall
Axle/Gears: 10 bolt, 3.73 Eaton Limited-Slip
Re: 89 L98 Hard Start issue
Have you checked the starter? Also, if it throws a code then something is most definitely wrong. EGR code means there's a problem with that. Usually that light comes on after a few minutes of driving.
Old Jun 1, 2011 | 06:31 PM
dhirocz's Avatar
Car: '86 IROC-Z/'94 Z28
Engine: 350 LT1/382 LT1
Transmission: 4L60-E/T-56
Axle/Gears: 3.45/3.42 (soon 4.10)
Make sure your PROM is for an '89, and ONLY an '89. That is the only year TPI's were MAF with the 165 ECM without the cold start injector. If you have an earlier PROM, it might be trying to use cold start enrichment through a non-existent injector.
A quick spritz of starting fluid in the plenum prior to cranking would help verify this, but the best way is to just run the numbers on the PROM.
Old Jun 2, 2011 | 11:13 AM
Knight98's Avatar
Car: Trans Am
Engine: 350 L98
Thanks guys. The EGR is new, I replaced that. As for the PROM, the numbers match for 89. I replaced the ECM but kept the PROM.
Old Jun 2, 2011 | 11:16 AM
Knight98's Avatar
Car: Trans Am
Engine: 350 L98
Oh
Knight98's Avatar
Car: Trans Am
Engine: 350 L98
Oh, yes I did check the starter. No problems with that. Was replaced by previous owner 4 years ago.
Old Jun 3, 2011 | 01:30 PM
dhirocz's Avatar
Where is the idle set? Timing? How many IAC counts at idle?
Old Jun 3, 2011 | 08:21 PM
Reid Fleming's Avatar
Car: 1989 GTA
Engine: SuperRam 350
Transmission: Pro Built S/S TH700R4
You've never changed the battery cables have you? Once those wires get corroded, they can build up resistance. Giving you all sorts of odd issues. Sometimes it will start fine, other times it will run like crap.
Even if the connectors look good, you never know what's inside the hidden part of the cable.
Old Jun 6, 2011 | 10:37 AM
Knight98's Avatar
Car: Trans Am
Engine: 350 L98
I belive idle is 650 at 15 counts. I will try the battery cables this weekend.
T
Old Jun 6, 2011 | 10:56 AM
no_car_yet's Avatar
temperature sensor right on front of the manifold solved my similar problem! only 15 bux + 10 mins labor!
Old Jun 12, 2011 | 06:47 PM
swiss's Avatar
^ +1 to that Had the same experience.
Old Jun 15, 2011 | 11:41 AM
6speedIROC's Avatar
Car: 86 IROC
Engine: LQ4 6.0L
Axle/Gears: 3.55 8.8
When it doesn't start are you getting spark?
Maybe your ignition in the column is not providing power to the distributor and only to the starter...
Check for voltage on the pink wire to the distributor on the HEI cars.
Old Jul 5, 2011 | 08:42 AM
Knight98's Avatar
Car: Trans Am
Engine: 350 L98
Thanks all for input. I replaced knock sensor and the the Coolent Temp sensor. Car starts like a champ.
Azrael91966669
25
Jun 20, 2017 04:04 AM
TheExaminer
Aug 19, 2015 10:07 PM
86White_T/A305
Aug 17, 2015 12:16 AM
cstrobel65
Aug 15, 2015 10:19 AM
86Base
Aug 8, 2015 01:34 PM
