setting my timing....
Old Apr 16, 2002 | 11:36 AM
Don_89Iroc's Avatar
to set the timing up and down which way do you turn the distributer, i know its suppose to be set on 6* and should idel at about 600rpm's when its warmed up but i need to know which way to turn the distributer to set it up or down, Thanks for you help -Don
Old Apr 16, 2002 | 08:22 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Don,
The procedure is to disconnect the EST bypass connector, and set the timing to 6* BTDC. Shut the car off and reconnect the EST Bypass connector.
That said, CCW will advance the timing, CW will retard the timing.
Old Apr 17, 2002 | 06:31 AM
Don_89Iroc's Avatar
how do i bypass the BSP?? what is the BSP??
Old Apr 17, 2002 | 06:32 AM
Don_89Iroc's Avatar
opps EST how do i d/c that? my bad
Old Apr 17, 2002 | 09:29 AM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Don,
Locate a single wire connector tan/black (IIRC) behind the paas side strut tower. Unplug it to set the base timing.
Old Apr 17, 2002 | 07:08 PM
Don_89Iroc's Avatar
thanks Mike :hail:
Old Apr 17, 2002 | 07:11 PM
Don_89Iroc's Avatar
wait i just read your earlier reply, so i start the car, unplug the wire, set the timing then turn the car off and plug the wire back in?? right?? i hope so geezus
Old Apr 17, 2002 | 07:19 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Yes....the reason you do it this way is so that the SE light will go out.
Old Apr 18, 2002 | 04:56 PM
BlazinOR's Avatar
Originally posted by 8Mike9
Don,
Dumb question - please forgive me - what if you simply moved the distributor without disconnecting the EST connector? Would it still 'advance' or 'retard' the timing?
Old Apr 18, 2002 | 07:38 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Not a dumb question, but something I've never tried, my guess would be that the basetiming vs spark curve would be off by how many degrees you moved the distributor...i/e the timing curve would be too agressive or too late.
Again, I don't know for sure, just guessing. I would bet that Glenn or Grumpy, or any of the other PROM burners could tell you for sure.
82tabird
Dec 21, 2015 10:22 PM
lt1z350
Sep 29, 2015 01:50 PM
hydrolic144
Aug 29, 2015 04:14 PM
IROCZDAVE (88-L98)
Exterior Parts for Sale
Aug 24, 2015 06:52 AM
mustangdmurder
Aug 21, 2015 07:17 PM
