How are runner lengths measured?
Old Apr 17, 2002 | 01:16 PM
MikeS's Avatar
When you measure runner lengths, is it measured along the center? Is it an average? Just wondering where all these runner lenghts for different runners, bases, etc come from. I'll take any info I can on the subject.
Old Apr 17, 2002 | 02:38 PM
Ed Maher's Avatar
Car: 04 GTO
Transmission: M12 T56
Honestly i don't know if they are short side, or ideal center lengths. Center would probably be the idealized number to use though. If you're getting your numbers from the same source i'd hope they're all measured the same way though so at least the comaprison is valid.
Old Apr 17, 2002 | 02:55 PM
Jim 86 IROC's Avatar
Car: 1988 Vette; 1988 IROC Z-28
Engine: 350cid; 305cid
Transmission: 700R/4; 700R/4
Axle/Gears: 2.59; 2.77
I don't think it matters. If you average the inside and outside arc lenghts it should equal the center arc length.
The important issue is that they measure from the inside of the plenum hole to the back of the intake valve in all cases.
Linson
Oct 24, 2025 02:00 PM
MoJoe
Members Camaros
33
Feb 6, 2025 09:47 PM
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
Royal_Z
Sep 30, 2015 08:45 PM
