How fast can I go w/$3000 on a 12.90 car?
Old Apr 18, 2002 | 09:43 AM
89IROCZZ4's Avatar
So far, I have a ZZ4, headers, stock tpi, 3.73 gears, 2000 dacco stall converter, 3"exhaust, sub frame connectors and other little things. What would you all suggest I get to go faaast? And how fast could I go? Is hi 10/lo 11 possible? No power adders by the way I was thinking maybe a high stall, fastburn heads, HOT cam and SuperRam/Miniram....What do you think?
Old Apr 18, 2002 | 10:04 AM
GofasterFirebird's Avatar
Car: 1991 Firebird
Engine: 427 LSX
Transmission: Turbo 400
OK, you are trying to go low 11's with no power adder on a 350 and use pump gas?? I think this a bit unrealistic. Going from 12.9 to 10.9 needs quite a bit more power than from 14.9 to 12.9. IMO you have very few parts that are up to 10.9 level. Why no power adders?? What is your mph right now?? I think with 3000 you can add quite a bit of power though.
Old Apr 18, 2002 | 10:59 AM
89IROCZZ4's Avatar
Thanks for the reply!
In reality, I already have a fully ported SuperRam and an ATI P600B. The ZZ4 has 10:1 cr and I am actually thinking about selling the SR and getting fastburn heads to lower the cr to 9.6:1. I don't know if it will help hp at all if I keep the stock tpi. I'm just weighing my options.
Old Apr 18, 2002 | 11:07 AM
Car: 1991 Firebird
Engine: 427 LSX
what is your mph right now?????????????????
so you plan to use the blower or not??? give more details
Old Apr 18, 2002 | 11:08 AM
Free Bird's Avatar
Car: 91 GTA and 85 IROC
Engine: 355
Transmission: gear jammer
Axle/Gears: 4.11
Stock TPI blows a big one. I also have a ZZ4 and dyno'ed at the wheels at 257hp/ but I did have 356 tq.
Good luck.
Old Apr 18, 2002 | 11:32 AM
89IROCZZ4's Avatar
Gofasterbird, my mph (best) was 107mph and that was the 12.9 run. As of now, I am planning on running the blower 12psi w/3 core intercooler and having it tuned well at a dyno place. I am also planning on selling the SR, getting fastburn heads, selling the zz4 heads and getting either a better intake used or a better torque converter.
Freebird, what other mods do you have?
Old Apr 18, 2002 | 11:39 AM
Car: 1991 Firebird
Engine: 427 LSX
is that a g=tech time?? You have stock runners??
Old Apr 18, 2002 | 12:03 PM
89IROCZZ4's Avatar
yes, that is a g-tech time and yes I have stock runners...stock base and stock plenum as well. I am not sure how confident I am in the mph but I am confident in the time. I took it to the track before the subframe connectors, with just a stock stall, and before several other things (including 2.73 gears) and I hit a 13.4 without launching, and with peeling out
Old Apr 18, 2002 | 04:12 PM
360Iroc's Avatar
I'd say put the procharger on it and you could see 11's
Old Apr 18, 2002 | 04:35 PM
Car: 1991 Firebird
Engine: 427 LSX
i knew that 107 was hokey. I think more like 101 mph.
Anyhow, I really have no idea of your intensions and what parts you do and do not have. Like, you have a superram, and are selling it. Why? Buying fastburn heads for the bigger chamber? I thing pimpjetta has it right. put the parts you have on it now(with some thick head gaskets or/and maybe remove jagged edges in the chambers), tune it and save the rest of the money for stuff that breaks. Your first post was so misleading, I feel cheated as a tgdo member.
Old Apr 18, 2002 | 05:38 PM
89IROCZZ4's Avatar
lol you feel cheated? why? haha. Anyway, I am thinking fastburn heads for the lower compression ratio. I am married and have kid on the way that is why I wouldn't have any other money to play will. Also, at the track when I ran a 13.4, the mph was 105.
Old Apr 18, 2002 | 07:34 PM
Matt87GTA's Avatar
Car: 1987 Trans Am GTA
Engine: Miniram'd 383, 24X LS1 PCM
Transmission: TH700R4, 4200 stall
Axle/Gears: 9", 4.33:1
Yeah, those G-tech times are not to be trusted as concrete. For example, my car had a trap of 111mph and only turned a 13.3.... I think I would have to assume that I would only get around a 104-5 trap in the 1/4 with my car and maybe a high 12 with sticky tires.
Another example of a wacky combo is my buddies Malibu with a stroked 400 in it with all kinds of goodies. He tried to G-tech his car on Sunday but just couldn't get enough traction to get it to do a reasonable time. He gets mondo mph though.... His last G-tech run was a 12.73 at 121mph.... lol.... :sillylol:
Old Apr 22, 2002 | 11:52 AM
Free Bird's Avatar
Engine: 355
Axle/Gears: 4.11
Check the sig
Bubbajones_ya
Jul 6, 2024 08:32 PM
InfernalVortex
Apr 20, 2021 11:31 AM
grngryoutmyway
Oct 18, 2016 05:48 PM
92-Formula
Dec 12, 2015 10:34 PM
Nervous2
Oct 8, 2015 10:53 PM
