cold air in camaro's
Old Apr 18, 2002 | 11:17 PM
britered86transam's Avatar
hey guys, need some ideas for a cold air induction for a camaro, lemme some pics of yours in TPI!
Old Apr 19, 2002 | 04:02 PM
tpi_roc's Avatar
get an slp or stay stock
Apparently Stock flows good enough to almost out power CAI considering the length differences
Old Apr 19, 2002 | 04:18 PM
Jim 86 IROC's Avatar
Car: 1988 Vette; 1988 IROC Z-28
Engine: 350cid; 305cid
Transmission: 700R/4; 700R/4
Axle/Gears: 2.59; 2.77
Cut the bottoms off the air boxes, run some 4" dia. flex Al tubing from inside the air boxes behind the cross piece and in front of the radiator to behind the fogs. Cost about $10 and does the job.
Do a search for ideas on how to incorporate a scoop behind the fogs if you want one; else just use the fog light mounts to hold the tubing in place. It should be worth 0.5-1mph in the 1/4mi.
I've been running it on the IROC for >4yrs and no water pickup problems either.
Old Apr 19, 2002 | 05:56 PM
Ed Maher's Avatar
Car: 04 GTO
Transmission: M12 T56
Yup. The only hard evidence collected so far between stock and homemade cold air shows stock winning or a tie.
The ram air mod that jim goes over is pretty common and a lot of folks show gains. It's cheap and only uses the cars stock openings so it looks good.
kyle5647
Aug 15, 2015 11:56 PM
drathaar907
Aug 6, 2015 04:20 PM
