How to bypass knock sensor?
Old Apr 21, 2002 | 10:41 AM
BlazinOR's Avatar
Need to try to bypass my KS without setting a code so I can check a minor drivability problem..........I know I can unplug it but will that set a code? I assume so..........but I'm ignorant so help me please. Or even how to 'desensitize' it?
Thought I remember reading that you needed to use some kind of resistor..........thanks.
Old Apr 21, 2002 | 12:05 PM
pontiac's Avatar
measure knock sensor resistance and replace it with right resistor. in other words ground the resistor and connect knock sensor wire to it. some people said it's 3.9kOhm, but i think it's better to measure the value.
-P
Old Apr 21, 2002 | 07:35 PM
Ed Maher's Avatar
Car: 04 GTO
Transmission: M12 T56
90-92 speed density ECMs all use 3.9k ohm
As for the MAF, i can't say for sure. Some are definitely 100k. I don't know if all are. Easy enough to be sure by measuring on MAF. Or you can buy apack of both for under $1 and try both. Start with the 100k, it will set a check engine light pretty quick if it's wrong, and it won't hurt anything.
Old Apr 21, 2002 | 07:37 PM
Ed Maher's Avatar
Car: 04 GTO
As for desensitizing, you can put a resistor network around the sensor to effectively 'quiet' it. Post back if you want to try this and i'll figure out the values you'd need.
Old Apr 22, 2002 | 10:25 AM
BlazinOR's Avatar
Ed, I have Speed Density. Sorry to ask this, but can you walk me through this? Am I buying these at Radio Shack? How exactly do I incorporate the resistor?
Thanks very much.............
Old Apr 22, 2002 | 03:53 PM
Ed Maher's Avatar
Car: 04 GTO
You can either hook it up at the sensor connector, or splice in at the ecm to make it cleaner and more permanent. You just hook up a 3.9k ohm resistor in place of the knock sensor. Just connect the resitor to the wire on one end, and ground on the other.
Old Apr 22, 2002 | 04:00 PM
BlazinOR's Avatar
Thank you very much.
Old May 18, 2003 | 02:41 AM
12 Sec GTA's Avatar
Car: 98 Camaro SS
Transmission: M6
What wire on the ECM is the knock sensor signal wire?
165 ECM
Old May 19, 2003 | 02:18 AM
Kingtal0n's Avatar
Car: 5.3L turbo 2800lbs RWD
Transmission: 4l80e
Axle/Gears: 3.512
oh crap. all this time i was like "ok found a 350 knock sensor" for my TPI swap, 165 ECM. now im wondering if its the right one!
oh sheesh. can i change the knock sensor "type" in the chip to accept any knock sensor? i dont want to hook this thing up then be chasing codes around left and right.
L98GTA87
Oct 19, 2015 10:43 PM
cking99
Sep 22, 2015 11:33 AM
sreZ28
Carburetors
24
Sep 21, 2015 04:54 PM
BLK87Z
Sep 18, 2015 11:29 PM
FormulasOnly
Sep 10, 2015 09:07 PM
