Chip Question
Old Apr 21, 2002 | 11:20 PM
ORAY777's Avatar
Chip Question
Anyone out there know of any companies that can remove the EGR Diagnostic which usually appears as code 32. I'm always havng problems with this code and i heard somewhere that it can be removed or something can be done so the code will not be thrown.
Old Apr 21, 2002 | 11:25 PM
89Warbird's Avatar
Car: 1989 GTA Nighthawk
Engine: 389 CID TPI
Transmission: TCI 700R4
Axle/Gears: 9 bolt 3.23
Any custom chip maker.
Old Apr 22, 2002 | 02:11 AM
Jim 86 IROC's Avatar
Car: 1988 Vette; 1988 IROC Z-28
Engine: 350cid; 305cid
Transmission: 700R/4; 700R/4
Axle/Gears: 2.59; 2.77
First measure the voltages involved with a DMM (I believe they are both 5Vdc). If all is OK disconnect the EGR Temperature switch feedback wire from the switch and jumper it to the EGR Solenoid command wire. This will let the ECM see the correct feedback when, and only when, it commands the EGR On. That should cure the code issue.
If no code within a minute or two after startup, take the car out onto the interstate and drive it at a steady speed for over 2minutes above 2,000rpm to check it out.
Of course you could always R&R the EGR system.
Frozer!!!
Jan 19, 2024 04:55 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
Bryan F
Aug 18, 2015 02:28 PM
redmaroz
Aug 16, 2015 11:40 PM
Exxon Limited
Aug 9, 2015 08:13 PM
