While I have the plenum off....
Old Apr 24, 2002 | 05:37 PM
Arawn's Avatar
Since I have the tpi plenum off, is there anything else I should replace? I got all the gaskets for around the plenum. Should I bother replacing the EGR (I think that's what that big round thing under the plenum is)?
Old Apr 24, 2002 | 06:58 PM
Jim 86 IROC's Avatar
Car: 1988 Vette; 1988 IROC Z-28
Engine: 350cid; 305cid
Transmission: 700R/4; 700R/4
Axle/Gears: 2.59; 2.77
So it is; you could at least pull it and clean it; use some anti-sieze on the bolts upon replacement.
Now would be a good time to move the MAT sensor into the air filter box. I got a 3/8" pipe thread plumbing fitting with a "vacuum" extension that I capped with a vacuum nipple.
Old Apr 25, 2002 | 11:07 PM
rondubbs's Avatar
if you have a MAF car, there is no reason to justify moving the MAT. do a search, the prom guys have proved this.
Old Apr 26, 2002 | 01:25 AM
BitchinCamaro's Avatar
Yeah, don't bother moving the MAT. Clean out the plenum real well, they get some nasty build up. If you own a dremal you could knock out the EGR walls and pick up a couple horses.
88SS6SPEED
Nov 11, 2015 07:05 AM
toronto formula
19
Oct 6, 2015 12:27 PM
italiano67
Sep 22, 2015 08:42 AM
