TPI vs MPFI
Car: 1988 Trans Am GTA
Engine: 5.7L TPI (L98)
Transmission: 700RJunk
You could have a MPFI induction system with tuned runners so a better comparison would be batch-fire injection vs. MPFI, in which case MPFI would be better because the injectors are firing right when their respective intake valve opens, not all at the same time.
2011 Norwood Gathering
ThirdGen Firebird Rep
Car: 99 WS6 / 00 SS / 11 CTS-V / 13 300
Engine: LS1 / LS1 / LSA / 5.7 Hemi
Transmission: 4L60E / T-56 / 6L80E / W5A80
Axle/Gears: 3.23 / 3.42 Auburn / 3.23 / 2.62
MPFI IS batch fired....SFI is the one Red Firebird is talking about.
That is the difference between "MPFI" and "SFI." SFI fires sequentially, when the valve opens, not all the time. Thats what MPFI does.
I have SFI on my '95 Grand Am and my '97 Z28, and had MPI on my '89 Camaro 2.8. I've already researched all this stuff
To answer the first question, TPI is a type of MPFI! TPI got the "T" due to its tuned-length intake runners. Now, I've been a TPI owner for about 2 weeks, so I'll let someone else get into the true details. But TPI IS a type of MPFI. Both are batch fire.
Hope I didn't confuse anyone
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
I assume when you refer to MPFI you mean the converted 4 barrel manifold styles that Edelbrock & Holley sell.
Car: 2006 Tacoma X-Runner
Engine: 4.0L DOHC V6
Transmission: 6-Speed Manual
Axle/Gears: 3:15 LSD
Yea those four barrel ones that Edelbrock sells. You can get them from Jeg's. Are those better than TPI? My friend swears that they are but I didn't think so.
Car: Death Mobile
Engine: 666 c.i.
To have SFI work in WOT you'd need fuel injectors 3-4 times larger than an equivalent batch fire injector.
Sooo... Which is better at acceleration and power TPI or those Edelbrock style MPFI?
Glenn,
Thanks for catching my goof...I knew that already
Car: 89 FORMULA FIREBIRD, 86 CHEVY CAMARO
Engine: L98, LB9 RESPECTIVLY
Transmission: 700 R4 (BOTH)
The TPI is better.
I contacted Edelbrock about thier mpfi setup, the only reply I got was that it would not work on a firebird, it was designed primarily for trucks.
Spend your money on some headers and better gears, maybe a cam.
John
John
Car: '87 Z
Engine: 355 in the works
Like John, that is designed mainly for trucks that had TBI. There was an episode of HorsePowerTV where they put it on a chevy truck... I think it was a 454SS or some kinda special edition truck... I don't remember that well.... I just remember it was a TBI and they used the MPFI that looks like a 4 barrel, and they gained like 30-50hp or something.
Sanjay
Aug 12, 2015 03:41 PM
