How do I get this darn thing off?!?!?!
Old Apr 28, 2002 | 12:35 AM
Dr. Lightning IV's Avatar
Car: 1987 Camaro Z28, 1998 Dodge Dakota Custom
Engine: 5.0L 305 TPI(Camaro), 5.2L 318 V8 Magnum(truck)
Transmission: 700-R4(Camaro)
There comes a time in a man's life where he must give up something he cherishes dearly. But in this case, I'm ready to get rid of it......I have finally found an engine for my car, and I'm trying to remove the tuned port from my engine to put on my new engine. but it's a stubbourn SOB. Is there a special way I need to go about getting this thing off the block? I appreciate it........
Old Apr 28, 2002 | 01:23 AM
Kevin 88's Avatar
Car: 88 Corvette
Engine: 400, AFR heads, ZZ9, SuperRam, 730
Transmission: Slushbox
Not in one piece. You have to disassemble it to remove it. Throttle body, then plenum, then runners...
Old Apr 28, 2002 | 10:28 PM
88 WS6 TransAm GTA's Avatar
Car: 92 Trans Am 'Vert
Transmission: 5 Speed
Yeah, the injection needs to be taken off piece by piece. You can leave the throttle body attached to the plenum however.
Remove the plennum/tb.
Remove the runners. There are bolts coming from the back of the runners as well, youll need to get to them from the oposite sides.
Remove the fuel rail.
Remove the intake manifold.
Installation is reverse of removal! (haynes rip off)
Old Apr 29, 2002 | 04:07 AM
Jza's Avatar
Jza
(haynes rip off)
hehe
Old Apr 29, 2002 | 10:15 AM
MikeS's Avatar
Take out the bolts
Just kidding. (well, you do actually have to take them out)
No real trick. Just start at the top and work your way down piece by piece. Throttle body first, then throttle cable, plenum, runners, things on the base, and then the base itself.
On a side note... I've got a head that I can't get off. Any ideas?
Old Apr 29, 2002 | 03:42 PM
Well, I have most of the blots taken off now, but the thing still doesn't want to come off. That and there is on bolt still on there on the right side on the top at the back that won't come off. I'm having the hardest fuc*ing time w/ it. I think I stripped it while trying to take it off. I'm not sure though. I am supposed to use a hex head when trying to remove everything.....right? It's worked thus far on most of the bolts, but I don't know how to get the rest of them off b/c the car has been sitting for 4 years and everything is either stuck on.....or is about to fall apart. Nothing noticeable on the outside, it's all under the car from the stupid weather. Any suggestions on how to loosen the bolts up just a smidge?
Old Apr 29, 2002 | 03:52 PM
86IROC305's Avatar
You need a t40 torx bit for the runners and a t45 for the lower intake IIRC. Just make sure the bit is seated good and there is no crap in the head of the bolt. What I had to do one time with a stripped runner bolt, was to gently hammer in a t45 in place of a t40 and use that to get it out. I can't think of any other way that doesn't involve JB weld to get one out. Hope this helps!
-Joe
Old Apr 29, 2002 | 08:35 PM
What does one of those look like? Our whole freakin' one car garage has soooooo many tools in it I don't know where to start. I know tools by look, not really by name. I know where everything is when it comes to the tool box, though, b/c that's organized. That and we have probably 4 of everything, so it shouldn't be hard once I know what I'm looking for. Prom is this Sat. and I'm screwed on the engine I found b/c I'm having to spend $120 on a tux, plus dinner, corsage, entry fee..... the list goes on. I'm glad I can always come home to my car, she always likes the things I get her, and never tells me I'm inconsiderate.....LOL. If only my car was running, that would be pimp...NOPE. I'm stuck having to take my friend's dad's new PT Cruiser b/c he's taking his date's dad's 76 Corvette Stingray :rockon: .....Oh well, it'll all be over soon......OH yea, T40 and T45, all I need is a description and I can find it. HA HA HA, I just had to get all of that out b4 I exploded. Thanks---
Old Apr 29, 2002 | 09:43 PM
92TPIZ28's Avatar
Car: 1992 Camaro Z28
Engine: 355
Transmission: T-5 w/centerforce dual friction plate clutch
the torx tool looks like a screw driver but the head kind of resembles a hex head, but has a little different shape to it.(just came from the store looking for one so i can take out my tb, plenum, and runners so i can clean and then bore the runners) hope this helps you out.
Old Apr 30, 2002 | 07:23 AM
MikeS's Avatar
Torx bits are star shaped. The T40, T45, etc names are just how you name different sizes. A T45 is slightly larger than a T40. If you don't have a set of torx (star) bits, you should go to the hardware store of auto parts store to pick up a set. They'll work much better than an allen wrench.
Old Apr 30, 2002 | 04:25 PM
camaro6spd's Avatar
got my set a wally world...work great, $12.00, i have like 10 different sizes only needed a few tho....oh well nice to have whole set...looks more professional
Old Apr 30, 2002 | 07:10 PM
Alright, I'm sorta in a goat fu*k....That one bolt that wouldn't come off...still won't come off. I've tried everything. After I found out what a torx tool was, I found that I had some in the box...but my bolts are T30's and the fu*king tool just spun in there when I used the air drill on it. So then I thought I had a genious idea to use a flat head screw driver to get it off by using the grinding wheel to cut it out like that. I swear I come up w/ the stupidest ideas...I hit up O'Rilley's to see what they had to say, but they couldn't help me b/c the car has been sitting for 3 years. The runners are firmly set onto the Plenium (or how ever you spell it) Any more bright ideas, b/c mine don't work Thanks...... :lala:
Old May 1, 2002 | 07:22 AM
MikeS's Avatar
The flat screwdriver jammed in there doesn't sound like all that bad of an idea since it sounds like you're getting down to last resorts. I've had to do that on smaller torx screws before. Maybe you can grab the head of the bolt with vice grips, channel locks, or some other kind of pliers to start it that way?
Old May 2, 2002 | 03:24 PM
I am down to last resorts. I tried using channel locks, but the head on the bolt is small and they keep slipping. I've pinched my hands so many times that I'm not going to try that again. I'm going to try the screw driver thing again today or some day when I'm not really pissed off at it, otherwise I'll do some serious damage to the car when it doesn't do what I want it to do. Thanks for not telling me I'm a fu*king idiot for the stupid sh*t I tried......anything that might be able to loosen the bolt up?
Old May 2, 2002 | 08:51 PM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
I am not sure if you tried this or not yet and I am not going to reread it again. try a good chizzle from the side of the bolt head so that it spins the bolt as you hit it. 30 deg. angle should be good. if that only shaves off the side then do the same to the other side and try the vise grips again now that you have two flat surfaces to grab.(use flat jaw VISE GRIP brand ones)
Bubbajones_ya
Aug 31, 2015 12:02 PM
TheExaminer
Aug 19, 2015 10:07 PM
Bob88GTA
Aug 18, 2015 03:31 PM
