Vette aluminum heads cfm?
Old Apr 28, 2002 | 09:57 PM
Swapmaster's Avatar
I have a pair of Vette aluminum heads. Off the same engine but
2 different cast numbers. One is a D port # 10088113 and
the other is not a D port # 14101128.
Are these heads worth porting or will the iron 350 heads like
the ones rhuarc30 is porting provide better flow?
Old Apr 28, 2002 | 10:29 PM
BitchinCamaro's Avatar
Here is some info for you, hope it helps.
10088113...88-up...350..........Aluminum, 58cc, angle plug, raised
"D" port exhaust, 1.94"/1.5" valves
14101128...86-87...350..........Aluminum, 58cc, angle plug
Old Apr 28, 2002 | 10:44 PM
rhuarc30's Avatar
Lot's of people have gotten good results porting the aluminum heads, I have not personally done a set of them so have no first hand results to give you. In general though I would not use 2 different heads on the same engine, even if the differences were only minor. I'd go with the D port 113 heads and just purchase one to match it. Shouldn't be too expensive, then you could port them. Be careful with porting though, aluminum cuts MUCH easier than iron so you can quickly ruin a set of heads if you are not careful.
My iron head project is mainly to show that the stock iron heads have plenty of potential and can make plenty of power. Most stock heads have plenty of room for improvement like that. I would wager that you could do a similar porting job to the aluminum heads and obtain good results. The smaller chamber will keep you to smaller valves is all.
Hope that answers your question.
Old Apr 28, 2002 | 10:45 PM
Swapmaster's Avatar
Excellent.
Now how far can they be ported?
The walls and roof look thin but the short side
radius seems to be fairly thick.
Old Apr 29, 2002 | 07:53 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
The car never came from the factory with 1 D port and one non D port head. Sounds like you got a mungrel. I'd find another d port head if I were you. Using 2 different heads isn't doing your motor any favors.
Old Apr 29, 2002 | 08:05 AM
Swapmaster's Avatar
I knew they were mismatched and I need to find another D port.
Anyone have a D port vette head they want to sell?
Nobody has ported flow numbers for these things?
Old Apr 29, 2002 | 08:24 AM
89ProchargedROC's Avatar
i know that Tom Craig was using fully ported out vette heads on a all motor 355 and was running in the 10s...but it wasn't a street car
Old Apr 29, 2002 | 01:35 PM
Swapmaster's Avatar
Anyone else have anything to add on porting these heads?
Old Apr 29, 2002 | 02:10 PM
Jim85IROC's Avatar
Ligenfelter is the porting champion when it comes to these heads. He's managed to get some amazing horsepower out of countless corvettes with stock ported heads.
Old Apr 29, 2002 | 03:04 PM
88TPI406GTA's Avatar
Car: 2009 Pontiac G8 GXP
Engine: LS3
Transmission: 6L80E
Actually, these heads with a full race port through Doug Rippie Motorsports or Hi-Tech Racing here in MN have ported them to flow 260 cfm at .500!!!!!
However, this is a full race port and costs like $1200-$1500. It shows the potential however and this setup is fully hand ported, hence the expense.
I have a set of mildly ported #113 castings that are bare right now that I am interested in selling. I just bought a set of Aluminum Pro Action 220 castings, so I don't need these anymore. Email for details if you are interested.
But definitely get at least ONE more #113 casting...running two different head castings is always a bad idea.
Old Feb 4, 2009 | 01:37 AM
Lou113's Avatar
Re: Vette aluminum heads cfm?
ive got a set of 113s ide be willing to let go hows 475 sound?
Old Feb 4, 2009 | 07:50 AM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
High, 6-years too late, and in the wrong section
Old Feb 4, 2009 | 04:12 PM
David 91RS/Z28's Avatar
I think you will have better results from the D port heads vs Iron. Also, porting for velocity and not peak air flow is what you want in flow. I think a fully ported set of these heads could support 450hp. Why don't you enlighten this thread on what you trying to do with the heads.
Old Feb 4, 2009 | 04:52 PM
Oops....sure is old! Oh-k!
midge54
Dec 27, 2019 04:14 PM
bdads
Aug 24, 2015 06:01 PM
Zeek1041
Theoretical and Street Racing
Aug 21, 2015 08:45 PM
86IROC112
Aug 17, 2015 02:00 PM
