How would you go about checking your MAP sensor
Old Apr 29, 2002 | 07:23 PM
86FyrBrd's Avatar
Car: 1992 Camaro Z28 Convertible Z03
Engine: 383 SuperRam
how would you check it, how would you change it, how much does one cost....I think that covers my questions
Old Apr 29, 2002 | 07:31 PM
Ed Maher's Avatar
Car: 04 GTO
Transmission: M12 T56
To check it you either need a scan tool to see what your ECM sees, or you need a digital voltmeter and a vacuum pump.
Then you either make sure it is giving reasonable values in the scan tool or put vacuum on it and measure voltage vs. vacuum. 30" vacuum should be ~0V and 5V should be o vacuum.
Old Apr 29, 2002 | 08:46 PM
86FyrBrd's Avatar
where is the sensor, if i have a new one would it be easier to just swap it and see if it fixes my problems
9192camaro
16
Feb 3, 2019 12:21 AM
soarestransam
Aug 24, 2015 08:15 AM
91REDZ28VERT
Aug 18, 2015 10:16 PM
squiggy2
Aug 9, 2015 09:30 PM
