how much hp will i gain
Old May 2, 2002 | 10:31 AM
iroc_z16's Avatar
How much hp will i gain if i put on world Sportsmen II heads, the hot cam from sdpc, hooker lt, hooker cat-back, and put 20 decals across the windows:rockon:
Old May 2, 2002 | 10:37 AM
Jim 86 IROC's Avatar
Car: 1988 Vette; 1988 IROC Z-28
Engine: 350cid; 305cid
Transmission: 700R/4; 700R/4
Axle/Gears: 2.59; 2.77
LB9 or L98?
Oh, and how large are the decals??
Old May 2, 2002 | 11:04 AM
BitchinCamaro's Avatar
Are you going to upgrade the TPI at all, that will be a restiction and cost power. But, of course, just use yellow stickers to make up for that, since yellow produces twice the power of any other sticker.
Old May 2, 2002 | 12:57 PM
TBurke's Avatar
With a stock TPI the car may slow down. The dart haeds have 200cc runners which is not great for low end torque. The heads are better at high rpms which a stock TPI cant take advantage of.
Old May 2, 2002 | 01:52 PM
iroc_z16's Avatar
It is a 87 350. I was getting the tpis big mouth manifold, slp runners, adn 58mm tb, which are the best heads for this motor.
Old May 2, 2002 | 02:21 PM
TBurke's Avatar
Most TPI guys like the AFR 190's. I have them and they are great.
I don't know about the Dart II's on a TPI motor. If anyone out there has done it let us know.
Old May 2, 2002 | 02:28 PM
rhuarc30's Avatar
The AFR's are a quite a bit better head than the darts for the tpi due to smaller ports and greater velocity. Dunno if the darts come with the right bolt patern either, if you have an 87 it'll have the 2 center bolts on each side of the intake at a different angle. The afr's are available with this, dunno bout the dart's.
Old May 2, 2002 | 02:59 PM
johndo1707's Avatar
afr 190's are also a lot more expensive.....
Old May 2, 2002 | 04:09 PM
On a 350 the right combo of heads, cam, exhaust and mild intake work should be worth 90-100hp. Don't forget to do cooling and upgrade the ignition.
I've added 60hp to my L98 without touching heads, cam or headers, so there is potential in there.
BTW, I would go with a 52mm TB instead of the 58mm. You may have tip in problems with that large a unit and 350/355 CID. It would be ok with a 383, etc.
Of course I'm partial to the Vette #113 heads pocket ported!
Old May 2, 2002 | 04:28 PM
Don_89Iroc's Avatar
what brand are the afr 190 heads? where can i find them and how much do they cost??
Old May 2, 2002 | 05:32 PM
Black 91 Z28's Avatar
Car: 1991 Camaro Z28
Afr 190s are made by Air Flow Research. You can look on http://www.airflowresearch.com/ for more info and prices. They are pretty expensive heads though.
David
smnichol86
Brakes
26
Mar 26, 2017 10:55 PM
antman89iroc
36
Jan 31, 2016 08:42 AM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
82xCAMAROxZ28
Sep 27, 2015 12:31 AM
IROCThe5.7L
Sep 17, 2015 07:48 AM
