Top End motor buildup ? Would it be worth....
Old May 4, 2002 | 03:36 PM
Mike86Z28's Avatar
Car: 98 Z28
Wondered if it would be worth it to put the lt4 hotcam, Afr 195 heads, Accel (miniram) Base intake, AFPR and headers on and leave the runners and plenum etc. stock for now and upgrade them when I get money or would I just be wasting my time unless I did it all at once?
I want to get my heads, cam, intake, and headers on the car but I really don't have the cash to fork over for the runners etc. right now. Should I wait or swap what I can?
Old May 4, 2002 | 03:44 PM
Ed Maher's Avatar
Car: 04 GTO
Transmission: M12 T56
If you ran AFR 195s with a siamesed accel base, stock runners, ported plenum and a LT4 hot cam you could run mid 12s with the right fuel system, tuning and torque converter. That SAME set-up has gone 11.9 in mike davis's car, a full weight 85 Z28 with the only difference being ASM LTRs & Vigilante torque converter. But damn right do the heads cam and base first, siamesing the base being key to letting it breathe.
Old May 4, 2002 | 03:54 PM
Mike86Z28's Avatar
Car: 98 Z28
Thanks for the help man....1 more question..... Hooker Supercomp shortie's (1 5/8) or should I save up and get the Slp 1 3/4 shortie's w/ AIR Delete? I plan to do the Headers the same time as the heads/cam/intake....
Old May 4, 2002 | 04:31 PM
Ed Maher's Avatar
Car: 04 GTO
Definitely run at least the 1 3/4 if you want to get the most out of that combo. 1 5/8 headers would definitely be your biggest restriction, even with stock runners on a deep breathing combo like that. Or if emmisions are never a concern (in OK and all) you might as well go all out and run the hooker supercomp long tubes. They're definitely the hot piece in the faster cars w/ the mufflex Y pipe.
Old May 4, 2002 | 06:29 PM
Mike86Z28's Avatar
Car: 98 Z28
That was an exaust setup I was thinking about (3 1/2" or 4")....the only problem I have w/ that would be the ground clearance from the headers....the roads out here in OK suck....potholes, bumps and every crappy thing on the road you can imagine...some roads are good but 90% of them suck . How would the ground clearance be w/ the long tubes?
Waiting for the gods of the 3rd gen to answer..... :hail:
Old May 4, 2002 | 06:36 PM
Mike86Z28's Avatar
Car: 98 Z28
Oh...forgot to mention....I am going to run LT1 Injectors w/ this setup...I can get them on ebay pretty cheap and I might even get them flowmatched....
1992 Trans Am
May 10, 2023 07:19 PM
customblackbird
Aug 15, 2021 10:16 PM
SiCkRs
Members Camaros
32
Jul 1, 2018 04:53 AM
Azrael91966669
25
Jun 20, 2017 04:04 AM
NBrehm
Aug 5, 2015 07:57 PM
