Timing connector
Old May 5, 2002 | 01:53 PM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Timing connector
Engine dies when it's disconnected ( not stumble, dies, shuts off) any clues what might cause this (can't set timing)?
Possible Module?
Old May 5, 2002 | 01:59 PM
91L98Z28's Avatar
Car: Z28
maybe the timing is already too far retarded, and when you unplug it, it goes so far retarded that engine won't run.
advance the dist about 5 degrees then unplug the wire and see if it stays running, if not try 5 degrees more....
Old May 5, 2002 | 04:32 PM
Dyno Don's Avatar
Nope, as I said it just shut off.
Found what it was: Accel Module, put stock one back in problem went away.
Thanks for reply.
Don>>>
Old May 5, 2002 | 05:25 PM
91L98Z28's Avatar
Car: Z28
glad to hear you found it, just thought i'd offer an alternative.
when i bought my 91z, for whatever reason the timing was about 15 degrees retarded from where it was supposed to be. if it had been retarded another few degrees, it would have died just as you described. as it was, when i unplugged the "timing wire", it almost died.
seems like people always come back to the stock GM module when it comes to distributors....
Old May 5, 2002 | 07:18 PM
Bort62's Avatar
When I bought my car, It turned out that the new owner was about 15* retarded as well.
Were Still working on resolving that issue.
eightsixseven
Dec 16, 2024 01:50 PM
Ghettobird52
Jul 5, 2024 11:18 PM
89GTAOz
May 16, 2020 09:31 AM
86White_T/A305
Aug 17, 2015 12:16 AM
