Oil pressure dropped....
Well, i went to work friday morning and i noticed that my oil pressure gauge was reading about 29 while cruising at about 60mph.... normally its about 55 or better at 60mph. So now, no matter what i cant get more than 30psi except when i first start the car and its cold, i get maybe 35. What does this mean? Time to start building the 383? or maybe just the gauge?
Car: 1989 IROC
My car did that back when I had all of the stock gauges in it. I had just replaced the motor so i knew it could not be dropping pressure. Anyway, it turned out that it was just the sending unit in the block. I replaced that and the problem was solved.
Tim
Tim
