I think i found the problem!!!!!
Old May 7, 2002 | 11:44 PM
86305's Avatar
Ok heres the deal. My cars been running like crap. WIll it run with a bad ecm. And not set any codes. I can unplug sensors and it doesn't change anything.
Old May 8, 2002 | 03:18 AM
Arawn's Avatar
Does it throw a code when you disconnect any of the sensors? mine set a 21 when I unplugged the TPS. and are you sure the SES light bulb isn't blown?
Old May 8, 2002 | 06:08 AM
SLOW5.0's Avatar
Accel cap and rotor made mine run like crap till I changed it out for A/C Delco cap and rotor
Old May 8, 2002 | 11:33 AM
tpi_roc's Avatar
Unplug the MAF, thats one sure fire wall (and easy) to get it into limp.
Old May 8, 2002 | 10:14 PM
86305's Avatar
occasionaly while driveing the ses light comes on but it will go back off. When i stop and check it i get no codes. I've unplugg every sensor one by one and it changes nothing. Hell i even took the tps off.
Old May 8, 2002 | 10:51 PM
72LT1VETTE's Avatar
Car: 1972 LT1 Corvette
Engine: 350 HO
Transmission: M22 Heavy Duty 4 Spd
Axle/Gears: 336
Codes do not clear themselves. If the SES light comes on while driving, it's still in there. Will only delete when power is removed for a few minutes or reset by code scanner. Check your code reader. Will flash 12 then all codes in memory then 12 again.
Old May 8, 2002 | 11:14 PM
RedFirebird's Avatar
Car: 1988 Trans Am GTA
Engine: 5.7L TPI (L98)
Transmission: 700RJunk
I second that about accel cap and rotors. They flat out suck. The rotor is too tall and the top of it chews up the distributor cap. Gets this fine plastic dust/shavings all over the place and on the terminals under the cap. And i didn't get a "bad" kit because i'm far from the only one who has discovered this problem..........
SpaniardV6
Brakes
19
Sep 7, 2015 03:04 AM
Bert87
Aug 23, 2015 03:50 PM
bjpotter
Aug 12, 2015 06:06 PM
Fronzizzle
Aug 9, 2015 01:15 PM
antares57
Aug 6, 2015 07:47 AM
