lt1 cam
Old May 7, 2002 | 08:40 PM
maddmonkees90rs's Avatar
lt1 cam
i saw on ebay some one had a lt1 cam for sale. he said it would be a great up grade for tpi engines is taht right? im askin cus im in the middle of swappin to a speed density system and i know that u cant have to much cam. what cam would be best for my setup and do the 350 heads from a vette fit a 305 block. thanks
Old May 8, 2002 | 08:16 AM
Beefy89's Avatar
It depends on what you want the car to do.
If you want to race the car regularly,I would get something bigger.
If your looking for a little more performance in a daily driven car,then it is a good cam.
It also depends on which LT1 cam it is.The 96 LT1 cam I installed in my L98 is .447"/.459" lift 205/207 duration @.05 117 lsa.I also added 1.6 roller tips for a little more lift......
Old May 8, 2002 | 11:30 AM
tpi_roc's Avatar
Its a *fair* cam for a 305.
Personally For the intake I never understood why LT1's had such wussy cams.
Old May 8, 2002 | 11:49 AM
Beefy89's Avatar
Aside from the LT4 hot cam,and maybe the ZZ4 cam,what GM cams aren't wussies?????????
Old May 8, 2002 | 11:52 AM
tpi_roc's Avatar
ZZ3's not bad at all.
its lesser than LT4 but makes good torque
Old May 8, 2002 | 11:58 AM
Beefy89's Avatar
My LT1 cam makes good torque.
Just ask my BFGs............Not to metion my 2.78 60' times.
Old May 8, 2002 | 12:03 PM
tpi_roc's Avatar
Not offending the car
I doubt the cam is necissarily responsible for all the torque..
The duration is just super small, you could still make more torque with a degree or two more all around.
Old May 8, 2002 | 12:19 PM
Beefy89's Avatar
See if you can guess what kind of torque this cam makes?
.431/.451 lift,196/207 duration???????????????
Old May 8, 2002 | 12:41 PM
tpi_roc's Avatar
in a 302? 305? 327? 350? 355? 383? 396? 400?
Work with me man....
Old May 8, 2002 | 01:00 PM
Beefy89's Avatar
400 ft lbs of torque!
It's the cam from the RamJet 350.
So I guess having a small duration isn't exactly what you need to make gobs of torque.Right?
Makes my LT1 cam look BIG!!!!!!!!!!!!!!!!!!!!!!!
Old May 8, 2002 | 01:02 PM
tpi_roc's Avatar
You're not answering anything
Or giving any details
Old May 8, 2002 | 01:04 PM
Inwo's Avatar
Car: 2007 Saturn Sky Redline
Engine: 2.0 turbo
Transmission: m5
Axle/Gears: 3.91 LSD
WOW! 2.78 60' times?!? Way to go! You must really have taken off ALL your suspension and put a few extra batteries in the engine compartment to be as successful as that in your runs! Congrats!
Old May 8, 2002 | 01:09 PM
Beefy89's Avatar
I was stating the fact that the car is not hooking up.
Old May 8, 2002 | 01:10 PM
Beefy89's Avatar
What details are you looking for?
Old May 8, 2002 | 01:11 PM
tpi_roc's Avatar
You can run an lt1 cam SPECS in a big block and make 400ft/lbs, so what?
let me know what engine this supposed 400ft/lbs of torque is in and all the specs of it and i'll tell you WHY its making that torque.
Old May 8, 2002 | 01:35 PM
Beefy89's Avatar
The cam I'm talking about comes in the Ram Jet 350 which is a crate engine offered by GM.
It's 350 ci,9.4:1 compression,Vortec heads,.431/.451 lift,196/207 duration roller cam,and Ram Jet pfi.....
Old May 8, 2002 | 04:44 PM
Bort62's Avatar
I would say you Don't know how to Drive.
I could run a 4 second 60' If I just footbraked and launched it at WOT.
Whats your Point ?
Old May 8, 2002 | 11:38 PM
Beefy89's Avatar
Whats your Point ?
I did two pedal it off the line,then babied it somewhat to keep the tires from spinning,but it didn't work..The track I was at won't let you heat up "street tires"in the water box,so I was running on cold street tires.
The point I'm trying to make is that my "wussy"LT1 cam makes plenty of torque.As far as my driving is concerned,YES,it was the second time I ever ran a car at the track.
Do you get my point now AJ??
Jorlain
Oct 8, 2015 01:57 AM
New2Chevy
Sep 28, 2015 12:35 AM
88 TA GTA
LSX and LTX Parts
Sep 11, 2015 11:31 PM
L0tuS
Sep 4, 2015 11:16 PM
masonta
Sep 1, 2015 06:40 PM
