Smog Pump Removal
Old May 8, 2002 | 09:55 PM
HRC51's Avatar
Smog Pump Removal
I want to remove all of the emmisions equipment on my 89 Formula 350.
Does anybody know the GM Part# for the Idler pulley to replace the smog pump. Also I understand that you need a shorter belt or something because the route is slightly shorter? If so, does any body know what the corresponding belt # is?
I am doing this because I want to install long tube headers.
Any additional advice, pointers, and knowledge regarding this type of procedure would be appreciated.
Old May 8, 2002 | 10:15 PM
Poppa Chubby's Avatar
Car: Vert IROC Camaro
Engine: 355ci
Axle/Gears: 9-bolt w/3.45s
Just totally take the smog pump off and leave the empty spot open. You'll need a longer belt - 96.8 inches if I remember right. I just got done doing it to my car. There is a tech article somewhere for this removal.
There it is . . . https://www.thirdgen.org/newdesign/t...rpentine.shtml
Old May 9, 2002 | 06:08 AM
KYL98's Avatar
Car: 1991 Z28
If you remove the air tubes as well, what can you use to plug up the holes in the manifolds?? Does anybody make a plug for them or anything?
Old May 9, 2002 | 07:31 AM
Engine: 355ci
I didn't have to worry about - I put headers on right away.
I have heard of people plugging them somehow.
Old May 9, 2002 | 07:37 AM
MikeS's Avatar
You can get plugs for them at any hardware store. I haven't done it, so don't know the exact size, but it has been posted before. I do remember that it is a pipe thread, but can't remember the size. Maybe search for "AIR", "plug", and "size" all at once.
Old May 9, 2002 | 07:44 AM
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
Transmission: TH350
I did mine a few weeks ago. I think it was 1/4 inch. I took my air tube in and matched it up. I got the steel ones at a plumbing store. Dont go with the brass.
You dont need a pulley if you remove the smog pump, But if you remove the A/C then you will need a replacement pulley.
The A/C delete pulley #10055890. This is only If you remove your A/C compressor.
After I removed the smog and A/C, I had alot more room to work on the motor. I will be going to headers soon.
Old May 9, 2002 | 05:23 PM
90Form350's Avatar
does anyone know how this will affect emissions? I've heard that it cools down the cat at idle, and ive also heard that it makes the exhaust hotter to help burn off emissions.
Old May 9, 2002 | 06:18 PM
HRC51's Avatar
Yes, that is a good question. How bad will this really affect emissions. Do they go thru the roof or what? Should I also remove the EGR valve and plate off the intake manifold at the same time? Currently my car is nowhere near the limits as far as emissions are concerned it burns real clean.
Old May 10, 2002 | 07:18 AM
MikeS's Avatar
Here is how things worked on my last car:
First off, it was a non computer controlled 350 with vac advance distributor and Carter carb in an 84 Camaro. Since a 350 was not offered, they test it as a 305. I don't think that matters, since all of the gasses tested are in percentages and parts per million. Anyways, the only emissions controls that I had on the car was a catalytic converter. No smog pump, no EGR, just a cat. On a roller emissions test, my car would pretty much always fail on the first and second tests. However, using that information to tune the carb got it to pass. So, I would say that if your car is still set up basically like it is supposed to be (computer controlled carb still there, or fuel injection not swapped to carb or anything like that), it souldn't make a big enough difference to matter. As an extra precaution though, when getting tested without an AIR pump, make sure that the car has been running for a while so that the cat is fully heated.
Well, that's a little insight into the answer. Hope it helps.
Old Nov 10, 2010 | 10:41 PM
JimKlim's Avatar
Re: Smog Pump Removal
Go to any automotive store and get a 5/16 manifold plug that will do it for ya, they are brass or you can go to a fleet farm or what ever and get steel ones but the brass ones held up fine to the heat for me.
Old Aug 18, 2012 | 09:59 PM
jrhaus76's Avatar
Car: 1989 IROC-Z28
Engine: L98 - 350 TPI
Transmission: MD8 - 700R4
Axle/Gears: GH3/G80 - 2.77 POSI
THANKS!!!
Old Aug 19, 2012 | 03:18 PM
jrhaus76's Avatar
Car: 1989 IROC-Z28
Update: pump out. New belt on. Piece of cake! 10 minute job.
Old Aug 20, 2012 | 04:39 AM
haisud's Avatar
Will smog pump removing improve mpg?
Old Aug 20, 2012 | 04:57 AM
jrhaus76's Avatar
Car: 1989 IROC-Z28
No but a Civic will. With the crap mileage my car gets, and has since new, I don't really do things expecting or looking for mpg, I am looking to free up as much power as I can.
I can't emagine this will have any effect on the mileage.
Old Aug 20, 2012 | 05:06 AM
haisud's Avatar
this mod is for gain power? how much power?
RazorN8
Jan 7, 2022 11:44 AM
italiano67
Dec 11, 2016 09:21 AM
backtothe80s
Sep 5, 2015 12:39 AM
3rdgenparts
Aug 8, 2015 07:09 PM
mustangman65_79
Aug 7, 2015 09:55 PM
