L98 iron head ?'s
Old May 10, 2002 | 08:59 PM
rdog30's Avatar
Car: 85&95 Trans am
Engine: 85-LT1 95-LT1
Transmission: 4l60e & 4l60e
Axle/Gears: 3.23 & 3.23
L98 iron head ?'s
Got the zz4 cam yesterday. Was wondering on what size intake and exaust sizes I should go with on the heads. Cam specs are Dur@.050 208intake,221 exhaust. Lift .474" intake .510" exhaust. I'm going to use 1.6 roller rockers so I know the lift will increase. I was thinkinking of going w/2.02/1.60 inch intake and exaust valves and machine them down to 2.00/1.56. What do guys think? What kind of valve springs and roller rockers should I use?
Old May 10, 2002 | 11:08 PM
Bort62's Avatar
You need to get the Valve Guides Cut on the heads to accomodate the more then .480 lift w/o some serious isssues of two things trying to occupy the same space at the same time.
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Don't put that much money in L98 case iron heads they're not worth it.
Old May 11, 2002 | 02:35 AM
rdog30's Avatar
Car: 85&95 Trans am
Why not use the iron heads? They can flow just as good as the aluminum vette heads.
Old May 11, 2002 | 03:39 PM
rhuarc30's Avatar
Who says the iron heads are no good? with a little work, they can do pretty well. Check this thread out.
https://www.thirdgen.org/techbb2/sho...n+head+project
lt500r55
Sep 1, 2021 01:30 PM
Chuck84TA
Jul 15, 2016 09:05 PM
InfinityShade
Feb 21, 2016 01:29 PM
italiano67
Aug 31, 2015 06:04 PM
