My washer fluid bottle Mod
Old May 11, 2002 | 11:17 AM
MNformula350's Avatar
I took the combination washer fluid bottle/radiator overflow bottle assembley from a 91 Ford Explorer and put it in where my Charcoal canister used to be.
I think it really cleans up the engine compartment.
also in this pic you can see i have removed most of my A/C and i have also removed the smog pump and rerouted the serpintine belt.
Here
Old May 11, 2002 | 11:50 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Good idea.
Old May 11, 2002 | 05:34 PM
ZZsmpch's Avatar
Does that have the integral pump? That looks like the ticket for my Chevelle if it does.
Old May 13, 2002 | 04:01 AM
blk91z28's Avatar
Thats a very good idea, Im going to have to do that
Old May 13, 2002 | 06:08 AM
SLOW5.0's Avatar
nice...................very nice
Old May 13, 2002 | 08:50 AM
5.7lformula's Avatar
mmm
That seems like a hell of a idea. Since they are on 2 different side of the bay, do you just run a longer hose???
Jesse
Old May 13, 2002 | 09:19 AM
Thanx for the replies
Yes the washer pump is installed in the bottle itself.
I did have to run a longer hose for the radiator overflow bottle from the passenger side,the hose for the washer fliud bottle was a larger diameter than the stock one so i did have to replace all the hose.
Old May 13, 2002 | 08:24 PM
BOTTLEDZ28's Avatar
Transmission: A4
how was it bolted in? i have the SLP dual cold air kit and maybe i can mount that under the floor where you have it with alumium straps or something so no one can see it. does the overflow have to be equal or higher then the radiator cap
Old May 13, 2002 | 10:45 PM
mmm
My batt is on the side that you have yours mounted on. I would just have to figure it out. :-) Basicly the same thing just different side. I think the next pay day ill be lookin for this.
Great Job!!!
Jesse
Old May 14, 2002 | 12:55 AM
SUPER CHEVY66's Avatar
Car: 92 camaro, 06 trailblazer ss
Engine: 5.0 tbi, 6.0 ls2
Wow that looks clean i will be the next to do that mod.
Old May 14, 2002 | 02:57 AM
Gibby85's Avatar
Car: 85 IROC-Z
Engine: 305 TPI (stout rebuild)
Transmission: TH700R4 w/2200 stall
I likes, I likes!!
Old May 14, 2002 | 07:28 AM
Scott_92RS's Avatar
Car: 1992 RS
Engine: 406 Stealth Ram
I have to tell ya, when I clicked into this topic I was like "WTF? This is gonne be retarded.", but after seeing those pics, I was like "Damn, I gotta get me a tank from a 91 Frod Exploder!". Nice work man!!!
Old May 15, 2002 | 04:35 PM
Thanx for the compliments guys.
i have also seen the same bottles in full size F-150's not sure on the years though
bottledZr28-it bolts with two 10mm self tapping screws on each side on the top, i just put 2 holes into my core support on htat side and bolted it up.
Old May 15, 2002 | 06:01 PM
SATURN5's Avatar
Car: 84 SVO
Engine: Volvo headed 2.3T
Transmission: WCT5
Axle/Gears: 8.8" 3.73
Typically coolant overflows have a overflow for themselves. Mounting one below the radiator might cause a syphoning effect and drain the overflow each time it purged. Best to keep it close to level with the cap. cheers, Bob
Old May 15, 2002 | 11:12 PM
TPIterror's Avatar
Car: Formula
Transmission: M5
Hey, how hard is it to remove the a/c and smog pump?
Old May 16, 2002 | 10:56 AM
tpi_roc's Avatar
Ford parts?!?!?!? ACK!
Old May 16, 2002 | 11:05 AM
Scott 88 GTA's Avatar
Car: 88 GTA
Engine: modified L98
Axle/Gears: 3.27 9-bolt
That looks great. I'll have to do that in the near future.
Fireslash
Apr 11, 2016 06:43 PM
meeklay812
Oct 1, 2015 03:46 PM
dusterbd
Sep 29, 2015 08:40 AM
mfp189
Sep 27, 2015 09:25 AM
