ZZ4 cam and iron head ?
Old May 16, 2002 | 02:55 AM
rdog30's Avatar
Car: 85&95 Trans am
Engine: 85-LT1 95-LT1
Transmission: 4l60e & 4l60e
Axle/Gears: 3.23 & 3.23
What kind of porting needs to be done to the heads to match the cam. This is for my L98 motor. What size intake and exuast valves should I run?
Old May 16, 2002 | 09:31 AM
GTA91's Avatar
Car: '91 GTA
Engine: 402ci LS2
Transmission: faceplated T56
Axle/Gears: 9" w/ 4.11's
re: Rick
Rick, I'd stick with the stock 1.94/1.50? valves. I'd port the heads a little though. You'll need to machine the heads for the extra lift though, and try and find valve springs that will fit in the heads withOUT machining. I'll let ya know when I find my set. I think scoggin-dickey has them:
http://www.scoggindickey.com
*See ya saturday man
Old May 17, 2002 | 03:34 AM
rdog30's Avatar
Car: 85&95 Trans am
Cool! keep me updated cause I was going to go with some 2.02/1.60 valves and machine them down to 2.00/1.56. What ever you get should work for me since your cam is going to bigger than mine. Except on the lift.
Old Sep 4, 2002 | 05:59 AM
87transam5.7tpi's Avatar
I was thinking about putting in the zz4, and only change springs,retainers and the cam. will this work? I have ported my heads very well. I just didn't know if I would need anything else.
lt500r55
Sep 1, 2021 01:30 PM
junkcltr
Aug 2, 2019 11:12 PM
italiano67
Dec 11, 2016 09:21 AM
bamaboy0323
Sep 3, 2015 06:07 AM
