best place to get a new/used engine wiring harness.
Old May 16, 2002 | 07:10 PM
Camar_Hunter_c's Avatar
I have a 91 TBI that I am converting to TPI. I have the intake. I need to swap fuel pumps and comps for sure. BUT do I need a different wiring harness? I think I do, but not completely sure.
Any know a good place to get a good (CHEAP=under $100) harness?...
And another thing I beleive that the TBI distrib will work with the TPI system? Is this correct?...
Old May 16, 2002 | 07:18 PM
maddmonkees90rs's Avatar
dont do it!!
lol. try at ur own risk man. im in the middle of a swap and its a pain in the butt. ur using speed density and a harness is hard to come by. ebay. or maybe its just me. and i think ur right about the distbtor. yeah need the harness... some site modifies it for u for like 200 bucks or something. maybe u get lucky who knows
Old May 17, 2002 | 10:37 AM
tpi_roc's Avatar
MAF harnesses are a bit easier to find.
I've been looking for a reasonable SD harness for almost a year, they dont come cheap/easy.
There are a few aftermarket harness makers but non that I know of SPECIFICALLY for an F-BODY, which means you'll end up with your ECM somewhere other than its stock location, or at very least a big square hole in your fender wall.
Old May 17, 2002 | 11:12 AM
DM91RS's Avatar
Car: 91 RS
From what I've read on here the SD set-up is the way to go. Am I correct in thinking this?
Thanks, Darrell
Old May 17, 2002 | 11:16 AM
tpi_roc's Avatar
SD offers a few advantages.
    Maf has its own advantages, the ecm is better at calculating Air/Fuel with a stock computer and mods, but once you get into prom tuning My personal opinion is SD advantages out weigh MAF.
    On a side note, almost all current vehicles use BOTH sensors.
    Old May 17, 2002 | 12:27 PM
    I know it would be a pain...
    I know it would be a MAJOR PITA but coundn't someone just MAKE one?. I mean you get your pin outs for the ECM and run the wires? right?. I know it would be a major PITA but it would also be pretty cheap?... I have 2-4 weeks to get one so would I just be better off doing that?...
    I now I may be pioneering here, but hell I am also the one MAKING headers for the 60* V6's too so.. nothing new there...
    Old May 17, 2002 | 12:32 PM
    tpi_roc's Avatar
    yes it would be a major pain
    Not only that but by the time you go to GM and buy all the connectors for your harness you've spent more than what a painless wiring harness would have cost with labeled wires.
    There are a few people that hand make them and sell them, they probably get a price cut on the connectors buying in bulk thus resulting in a cheaper harness than you could make yourself.
    The last solution is to get a MAF harness, and repin it to a SD harness.
    Old May 17, 2002 | 06:24 PM
    Ok I have a MAF harness on the way...
    What do I have to "repin" to run S/D?...
    Old May 17, 2002 | 06:25 PM
    tpi_roc's Avatar
    http://www.eecis.udel.edu/~davis/z28/ecm_swap_730/
    Old May 18, 2002 | 06:36 PM
    Kick *** thanks.
    midge54
    Dec 27, 2019 04:14 PM
    Caspar
    Jun 19, 2016 11:19 PM
    Spyder_TheGamer
    Dec 25, 2015 05:07 PM
    bradleydeanuhl
    Aug 12, 2015 11:48 AM
