Fan Switch
Old May 21, 2002 | 09:25 PM
snoozeyaloose85's Avatar
Fan Switch
Does a 86 camaro with tpi and a single fan have a fan switch between cylinders 6 and 8? Cause mine doesnt. But my 85 TA with tpi and a single fan does. Also on the 86 the water temp gauge is in the water pump but on the 85 its in the drivers side head. I would like to know cause my fan in the 86 isnt turning on. Thanks
Old May 22, 2002 | 12:05 PM
tpi_roc's Avatar
Your CTS (coolant temperature sensor) Should be in the head.
Old May 23, 2002 | 09:00 AM
I'm talking about the fan switch and the water temp gauge sender. My cts is in the front of the intake.
Old May 23, 2002 | 09:39 AM
Brian'sIROC's Avatar
you should have the switch between cyliders 6 & 8. I would check to see if you have the wire that plugs in to the switch hanging around. My fans ran all the time when my fan switch was bad. If it's not coming on I would replace the coolant temp sensor or the fan relay. As far as the gauge sending unit, I've never heard of screwing them into the water pump. Just don't use teflon tape on that sending unit, it grounds to what its threaded into.
Bubbajones_ya
Jul 6, 2024 08:32 PM
gta892000
Aug 11, 2019 11:16 AM
FormulasOnly
Sep 10, 2015 09:07 PM
64goatman
Sep 9, 2015 01:09 PM
85Special
Sep 3, 2015 04:21 PM
