Whats a better head than the Trick Flows aside from AFR?
Old May 27, 2002 | 02:03 AM
Slow89Iroc-Z's Avatar
Car: 1989 Iroc-Z
Engine: 350ci SBC
I am looking for mid to low 12's with the LT4 Hot Cam with 1.6RR's and Holley Stealth Ram on a 1989 L98 bottom end and MAF computer. Is there a better bang for the buck head? I want a 190 to 200cc runner and 64cc combustion chambers and aluminum. Just dont post like blah blah is better....give reasons please...... I wanna stay around $1100 out the door ready to run.
Old May 27, 2002 | 02:50 AM
Morley's Avatar
Well if you are willing to spend that... CNC Trick Flows?
~M~
Old May 27, 2002 | 09:41 AM
ImportsRsloths's Avatar
I highly suggest u check out this site: http://www.mycar.net/mafb/registry/detail.cfm?id=201
Id also go with the AFR 190's, but if i couldnt get them for some crazy dumb reason that youll always regret, get the cnc trick flows
Old May 28, 2002 | 01:04 AM
Car: 1989 Iroc-Z
Engine: 350ci SBC
so Trick Flows CNCed are the next best thing huh?
Old May 28, 2002 | 02:06 AM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Axle/Gears: Strange 12-bolt
Check out canfield 195 cc heads
Old May 28, 2002 | 05:25 AM
John Millican's Avatar
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
Which Trick Flows are you talking about? The G2's or the 23° heads?
Old May 28, 2002 | 08:18 AM
Millican do you wish you would have gone with AFR 190's instead of those trick flow heads?
Old May 28, 2002 | 04:49 PM
Engine: 4.0L
No, I wish I would have gone with AFR 210's.
Old May 28, 2002 | 06:00 PM
formul8!!'s Avatar
Car: 2004 GTO
The Edelbrock Performer's look pretty nice. They are only $1050 out of Summit.
I would spend the extra $$$ and go AFR.
Old May 31, 2002 | 01:42 AM
Matt87GTA's Avatar
Car: 1987 Trans Am GTA
Engine: Miniram'd 383, 24X LS1 PCM
Transmission: TH700R4, 4200 stall
Axle/Gears: 9", 4.33:1
First, I am totally satisfied with my TFS 23* heads. My car may not be all that fast right now, but it certainly is not the fault of the heads (uh-hm..... stock base, PROM under construction, etc.).
That being said, I certainly would have been all over a set of AFRs if the money was there when I put my engine together.... So take that FWIW.....
Old May 31, 2002 | 07:02 AM
Randy92Z's Avatar
Car: 92 Z28 convertible
Engine: Miniram 383
Axle/Gears: 4.10 stk 10 bolt
When I was concidering my heads AFR 190's vs. TF 23* I thought the TF's and a cam would yeild more power than just the AFR's by themself's. Cost wise I mean. So thats what I did. The budget dident allow for AFR's and a cam.
LT1Formula
20
Nov 14, 2015 12:02 AM
Mickeyruder
Sep 2, 2015 02:45 PM
Dialed_In
Aug 20, 2015 01:45 PM
89mulletbird
Aug 12, 2015 07:08 PM
89mulletbird
Southern California Area
Aug 10, 2015 10:16 AM
