upgrading (i guess) to TPI
Car: 1991 Corvette Coupe
Transmission: 700R4/4L60 same trans different name
i have a fairly good idea on how to swap a TPI system onto my 87 Z28 LG4 305
i'm a little hesitant though because i dont know if its "right" for me
i was told by some people that they can actually limit power
and as of right now, my 305 is fairly quick (for a 305
) (ran a 14.8)
so i would kinda hate to be taking a step backwards and lose performance if i added TPI
whats your thoughts on this?
as for the swap i would need the following:
base manifold
plenum
runners
02 sensor
cooling temp sensor
MAT sensor
MAP sensor
IAT sensor
air filter housing
ECM
harness
throttle body
IAC
TPS
throttle cable
knock sensor
CC-advance distributor (already have one)
is there anybody here who has done the swap...........
what am i missing...........
how much am i gonna spend...........(about $1000)
also, i'm kinda shady on the idea that i will need to reprogram a PROM when i add a major performance piece (heads, cam, etc.)
i understand why and how its done, but i'm not the smartest person with that stuff
well, lemme just ask, how major of a PROM change would i need for vortec heads (yes, i know i need the special manifold from scoggin-dickie) and a comp cams 268 cam...................
thanx in advance
) (ran a 14.8)so i would kinda hate to be taking a step backwards and lose performance if i added TPI
base manifold
plenum
runners
02 sensor
cooling temp sensor
MAT sensor
MAP sensor
IAT sensor
air filter housing
ECM
harness
throttle body
IAC
TPS
throttle cable
knock sensor
thanx in advance
You won't limit power with the 305. You will gain a TON of torque though, which is driveability. $1000 sounds good if you shop for used parts. Don't worry about a PROM until yours doesn't work. You won't need one for heads anyway.
ok, but i do have a comp cam already
i believe its a mild one though................
and i forgot to add to the list a new hi-pressure fuel pump
ambainb
Apr 25, 2016 09:21 PM
Sanjay
Aug 12, 2015 03:41 PM
